Reverse Bleeding
Discussion in 'Technical' started by krkostecki, Feb 11, 2013.
  1. krkostecki
    krkostecki Active Member
    St. Louis, MO
    2007 Pitbull, 2008 Suzuki C109R
    Maximus
    Did a search on Mityvac and they were talking about reverse bleeding the brakes. Is it simply a matter of putting brake fluid in the Mityvac, hooking the hose to the caliper bleeder valve, opening the bleeder valve slightly, pumpling brake fluid up the brake line to the master cylinder until I see no more bubbles? Do I need to keep the brake pedal pumped (held down) during this? How much brake fluid should be left/kept in the master cylinder when completed to make sure the brakes work properly? I really enjoy learning new stuff - it's just very important for me to know HOW something works so I can understand what needs to happen to make it work
    Thank you for your continued support.
    Maximus
  2. Knuckles
    Knuckles Active Member
    Littleton, Colorado
    '07 K9
    Yep. Easy to do by yourself. No need to pump the brakes when reverse bleeding.
  3. krkostecki
    St. Louis, MO
    Maximus
    Thanks, Knuckles.
  4. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    Wild Steed Worx carries and uses this great reverse bleeding product.
    Reverse Bleeder
  5. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I bought that same one...call me stupid but I couldn't get the damn syringe to work properly I ended up just making a huge mess.
    I ended up just bleeding them the old fashioned way and was done in 10 minutes.
    I'll probably try that syringe again it's sitting on the shelf. I must have been doing it wrong, I'll try again.
    Not sure how..it seems straight foward...Uncover master cylinder, open bleeder, push brake fluid up through the hose till MC is full. :loony: Now that I think about it....maybe I didn't have the cover off???? :confused: Well that would be stupid no way for the fluid to go up I'll have to try again and make sure I'm not drinking too much beforehand. :cheers:
  6. Zachusmc
    Zachusmc Active Member
    Wi
    2007 k9
    Zach
    That sounds vary handy. Great info
    chubs likes this.
  7. KaptinAmerika
    2006 Big Dog K9
    Curtis
    Wow
    Not sure what to say to that bro.
    I use it and it works great. Although I do remove the cover......:lol:
    chubs likes this.
  8. Th3InfamousI
    Texas
    Sometimes when I'm in the garage I tend to grab a few beers and stare at the machine...sometimes it's a few too many to really be at the top of my game. haha :whoop: Who likes being at the top always anyways :lol:
    Twisted and chubs like this.
  9. Five Five
    Five Five Well-Known Member
    Southern California, The 714,
    2003 pit bull (sold) & 2006 K-9 (bought)
    Bill
    Take it easy Eric :cheers:
    chubs likes this.
  10. Ironmikey
    Ironmikey Member
    Sierra Vista, AZ. 85635
    2004 HD Dyna Low Rider; 2012 HD Custom Super Glide; 2006 Big Dog K9
    Mike
    I'm not finding the "MityVac" so #%!€¥&@ mighty. I've cleaned and blown the front caliper and MC. There was air going through each component of the whole system before I reassembled it closed bleeder valve, filled reservoir, attached L fitting to bleeder valve, pumped MityVac to 20", opened bleeder valve, watched vacuum gauge drop from 20" to 5" before closing valve. Waited ...and waited. I've done this at least ten times. No fresh brake fluid in sight. It's not dropping in the reservoir. It's not an air lock or blockage cuz air pressure pushed out what old brake fluid wasn't sucked out by the MityVac. Ideas?
    chubs likes this.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I don't think its a good idea to push the old dirty fluid back up thru the master cylinder plunger seals. When you have some air bubbles in the line, leave it sit over night, remove the master cylinder cap and tap the brake handle with the handle of a screw driver and watch the tiny bubbles come out.
    I don't know what year they switched to Dot-5 synthetic brake fluid, but it doesn't hold the moisture like Dot-3 or 4.
    dentdude36 likes this.
  12. Olde Man
    Olde Man Active Member
    Fort Wayne, IN
    2006 K-9
    John
    This is what worked for me to get the last of the air bubbles out. Turn the handlebars so the master cylinder is at its highest point. Pump the brake until it comes up to pressure. Electrical tape the brake lever in the compressed position and leave it set that way overnight. In the morning remove the tape and when the lever is released the caliper should push brake fluid back up the brake line and push any air bubbles that have collected at the top into the master cylinder. Easy Peasy
    BWG56 likes this.
  13. Reddickracing
    Reddickracing Active Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    06 K9. Just rebuilt the front calipers, what DOT brake fluid came in bike or should I use?
  14. Unsprung
    Ruskin, FL
    Gerald
    DOT 5. Has a purplish tint to it.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :agree:
  16. Reddickracing
    Louisiana
    Jeff
    10-4 Thanks
