ridgeback foot extenders
Discussion in 'General' started by Big Rob, Jan 5, 2019.
  1. LHS
    LHS Member
    Waterloo iowa
    2009 ridgeback 2004 Honda XR 650 L Dirtbike
    Lew
    Mine came with the gel seat when I bought it so I don’t have no way to compare the difference.
    The only real reason I suggested that Big Rob Check out one of the new gel push seats was to move him forward 2 inches that way he gets to save money ( Controls Versus gel push seat pricing ) and keep his matching purple powder coated forward controls. I would think though the gel seat would have to be more cushy than a Stock foam seat
    Like I said though I really have no way to tell the difference. Unless someone out there has a stock non-gel seat they would like to send me and I can try it out let you know LOL
  2. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
  3. Big Rob
    Big Rob Member
    Daphne, AL
    2005 Big Dog Ridgeback
    Rob
    Sorry guys, my phone hasnt notified me off all these replies. Im thinking a seat may be an easier route. I dont mind repowder coating new controls but a seat is a quick fix. Can anyone tell if my seat is stock or push? Here is a view showing the exhaust side as well someone mentioned.
  4. LHS
    LHS Member
    Waterloo iowa
    Lew
    Good evening Rob :oldthumbsup:
    I don’t believe that is a push Seat but I’m not 100% sure
    If you call Derek and Donna at ( Big dog motorcycle parts . 620-257-2009 ) with the measurements of your seat they will be able to tell you what you have and and fix you up.
    You could probably even send them a text with that picture of your seat and measurements and they’ll be able to tell from that I’m sure. When it comes to big dog motorcycle parts these are the people to talk to.They have two eBay stores with tons of Big Dog parts. One store is ( shovelheadkicker ) and the other one is (bigdogpartskingpin ) they have way more parts than what they are show on eBay so if You don’t see what you’re looking for just give them a call .
    Another good source for Big Dog parts is ( www.wildsteedworx.com ) Like I said Rob I’m not a 100% sure but I don’t think that is a push seat. The upper part on a push Seat from front to the Back fender I believe is a lot longer than what yours looks like and the angle down from the top to the bottom of the seat is steeper which gives you the 2 inch push forward.
    Don’t just take my word for it Rob because I’m definitely no expert on big dog bikes but Derek and Donna will definitely steer you in the right direction.
    Hope this helps and this day is good to you and the family bye:chopper:
    PS That is a good-looking dog you got there:old2:
  5. Big Rob
    Big Rob Member
    Daphne, AL
    Rob
    So i was thinking.....if im going to spend $300 on a push seat why not send my seat off to get reshaped to a push seat then customized with different stitching and material. Just need to find a reputable guy.
  6. mjsk9
    mjsk9 Active Member
    Carmel, IN
    2006 K9, 2008 BBC Pro Street Sled
    Mark
    I think it definitely is a "Push Seat". The first picture is a PS..... The second, is not.....
  7. JB105
    JB105 New Member
    Tuesday
    Wellsville Ny
    2006 K9
    Jeff
    If you haven’t already found your oil leak I would suspect it’s most likely your starter dripping primary fluid. Look on the back side of the primary plate there should be a vent there. Depending on the year if your bike especially if it’s a 2005 it may not have the vent which in that case one should be installed, if the starter is leaking just buy a new starter don’t bother with rebuilding.
  8. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Depending on how much oil is coming out, and if your starter is working fine, drain the primary. It may be over full. On that style of primary, if you just drain it and refill it, it takes 18oz of fluid. If you take the cove off and clean it out, it takes 20oz. Also blow out the vent in the back.
    chubs likes this.
  9. JB105
    JB105 New Member
    Tuesday
    Wellsville Ny
    2006 K9
    Jeff
    I’ve always run a full quart in my primary with no issues, the dealer I bought the bike from did replace the starter after developing a leak under warranty a year after I purchased the motorcycle new. I’ve had no problems since. I know the transmission only takes 20oz of fluid sometimes 18oz depending on if it all drains out when I do my seasonal change.
  10. Big Rob
    Big Rob Member
    Daphne, AL
    Rob
    This is new to me. The starter can leak? And what is the vent for on the primary?
  11. JB105
    JB105 New Member
    Tuesday
    Wellsville Ny
    2006 K9
    Jeff
    Yes the starter can leak. The primary builds up pressure and pushes the oil into the starter causing seal failure and then the oil fills the starter. The vent is to relieve the primary pressure. If you purchase a new starter be sure it has the relief cut in the nose but pay attention that you don’t get one with the relief cut too deep, contact Donna and Derek they have starters and actually came out with a new design to prevent the starter primary oil consumption.
  12. Big Rob
    Big Rob Member
    Daphne, AL
    Rob
    Very informative! Thanks
  13. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    We have found out that 18 oz is more than enough oil for these this primaries. All the oil is doing is lubing the chain.
  14. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    Contact Scott....he's done several members seats
    http://www.badassbikeseats.com/
  15. Big Rob
    Big Rob Member
    Daphne, AL
    Rob
    Email sent to him earlier yesterday. His work looks great! Waiting to hear from him.
