Spacers to lengthen handlebars...
Discussion in 'General' started by ChopperJeff, Apr 14, 2008.
  1. pauldeepsea
    pauldeepsea Well-Known Member
    California
    2004 Pitbull/ 2006 big bear sled 300
    Paul
    I will check it out but my pitbull handlebars are thicker than the big bear bars.
    chubs and francoblay1 like this.
  2. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    Your pit is an 04.... they might not be the same as the bars on the 05 and up?
    chubs likes this.
  3. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    They are the same 04 had the 1.5" bars too
  4. Guillaume
    Guillaume Active Member
    Baytown Texas
    K9 2007
    Guillaume
    chubs likes this.
  5. francoblay1
    K9 (2006)
    Franco
    Skully has not visited the Forum since January.
    chubs likes this.
  6. Rottweiler
    Rottweiler Active Member
    Elizabethtown, PA.
    2004 Chopper, 2014 HD Road King CVO, 1985 FXWG
    Todd
    So this is a old post but here goes. I want to raise my bars also. Did not want to cut a notch. How about chrome wheel spacers?
    They are 1.25 inch long and have .75 inside dia. could not find the outside dia. It looks close to 1.25 though. JP Cycles have them.
    http://www.jpcycles.com/product/2200152
    Will find a 3/4 inch rubber hose to fill the space between the 1/2 bolt and 3/4 inside dia. of spacer.
    BWG56, BadDawg Bill and chubs like this.
  7. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    2009 Big Dog Mastiff, Chrome Package, DOC's ESC, 585 cam, VH Big Radius Exhaust.
    John
    Why do you have to cut a notch? I have a set of 1" risers that I had on my 05 Bulldog and I never had to notch anything.
    chubs likes this.
  8. Bdawg12
    Bdawg12 Member
    Myrtlebeach
    2008 big dogg k9
    I would like to get some 1" risers myself chrome that will work on a 08 k9
    Sent from my SM-G920V using Tapatalk
    chubs likes this.
  9. Rottweiler
    Elizabethtown, PA.
    Todd
    John, See post 45 - 47 of this thread. Post 47 shows why, the riser are made to fit around the bottom of the bars. Big Dog has a welded plate across the bottom for speedo mount. Even though Joe did a excellent job notching them to fit. Looks good but chrome can start to peel. Also they where $68 plus bolts. With these spacers there will be two flat surfaces mating together and total cost with bolts is $36 plus tax / shipping. I'm also replacing the rubber bushings with poly from WSW so the steel insert from the old bushing might work for inside these spacers. http://www.wildsteedworx.com/index.php?main_page=product_info&cPath=65_68_173_72_99&products_id=473
    chubs and cdogg556 like this.
  10. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Mastiff bar spacers.jpg There's no notching with these! I don't know if someone just made these or what, I bought them back in 2011 from a member here at the time.
  11. HMAN
    HMAN Well-Known Member
    fk it
    These are some L.A.Chopper spacers that I stripped the chrome off and notched for my 04 Pit. Longer bolts were all I needed. 1 1/2" spacers. They have been on for about 5yrs?
    chubs, cdogg556 and dentdude36 like this.
  12. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Hey "Delicious", here's a bigger pic! :old2: And I gotta ask, what's up wif your name? Dont' know if I should be ask'n that but I gotta know! :oldsmile:
    chubs likes this.
  13. Rottweiler
    Elizabethtown, PA.
    Todd
    Yes I think someone made them, not sure where to buy them. What I am planning to do should look the same. Just have one bolt going through to handle bars. 3 3/4 inch long bolts.
    #73 Rottweiler, Dec 4, 2016
  14. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    I am sure they will work as long as you have a spacer inside the spacers to take up the gap between the bolt and the spacer, when you get them done post a few pics!
    chubs likes this.
  15. HMAN
    fk it
    Hahaha....my crew patched me in as Delicious, cause every time I cook for them that's all they say....lol
  16. Jersey Big Mike
    Jersey Big Mike Active Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    I put Pitbull bars on my K-9 -- what an improvement -- did have to change cables but it was worth it.
    PM me and maybe we can meet and you can check out the feel -- I'm just down the road from you!
    HMAN, chubs and dentdude36 like this.
  17. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Well that just goes to show where my mind is at![​IMG]:oldhardlaugh: I would have NEVER guessed that, pretty funny.:old2::old2:
    HMAN, BWG56, chubs and 1 other person like this.
  18. Rottweiler
    Elizabethtown, PA.
    Todd
    It's been a while, but I put in the handle bar spacer on yesterday. Here are some pics.
    Before Pics.
    [/ATTACH] 2017 Big Dog Work.jpg IMAG1779 (2).jpg
    Parts used.
    After Pics.
    I used the steel insert from the old rubber bushing for the space between the bolt and the wheel spacer. Worked Great.
  19. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Looks great! I'm sure it feels better too! :old2:
  20. Rottweiler
    Elizabethtown, PA.
    Todd
    Yes It feels great, the main reason was to keep the cables from hitting my gas tank. They made a mark on it.
    #80 Rottweiler, Sep 13, 2017
