Spark plugs
Discussion in 'General' started by LHS, Feb 11, 2019 at 4:49 AM.
  1. LHS
    LHS Member
    Waterloo iowa
    2009 ridgeback 2004 Honda XR 650 L Dirtbike
    Lew
    So what is the best spark plug to run in my 2009 ridgeback 117 S&S?
    Right now it has NGK DCPR7E in it. I was thinking about putting in the E3.36 plugs ?
    I have seen where the manual says to use champion only And I have also seen people useing / NGK’s / Autolite’s and numerous other spark plug Brands.
  2. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    If you do a search you will find 196 Threads discussing this same subject.... NGK & Champions seems to be the most used.
    :chopper:
    RBennet and Nukeranger like this.
  3. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
    I use Champions. Change them right before riding season.
  4. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Champions run the best.
    chubs and Nukeranger like this.
  5. heybaylor
    heybaylor Active Member
    East Texas
    Fatboy,Sportster,CX500, 2001 Pitbulll, Road Glide
    Carl
    Spark plugs are big business( billions ?)
    Why ? because almost every one can afford them and change them
    Most plugs do the same thing, that is to provide a arc to light off the fuel mixture.
    If the correct heat range and length is correct, and the Mixture is correct then they will wear out but that takes a long time
    (hundreds of hours)
    So the marketing begins, claims of more power, longer lasting, better mileage, etc etc
    And we the public buy into that .
    We change them like underwear ,usually for no reason other than marketing
    Also when ever a real or perceived problem with a engine shows up they are changed first without any diagnosis
    of the problem..(because almost anyone can do it)
    new plugs will mask the real reason a engine is not running correct ( bad mixture, carbon/oil fouling, faulty air cleaner,etc.
    bad spark from engine to plug (wires, distribution etc.)
    this only lasts until the new ones are contaminated.
    I have had a few go bad , some were bad out of the box(new doesn't mean it is good)
    But a couple of my bikes have over 25-40 k on the original plugs .
    never have changed my Big Dog (2001 107 with 10k )
    OK I have my flame retardant suit on :smash:
    francoblay1, chubs and KnotSo like this.
  6. chubs
    chubs Guru
    indiana
    2002 pitbull Prostreet --
    runky
    No need for flame retardant suit there! Everything you said is true. One other big reason for so many different brands is , unless you have a Diesel engine or electric vehicle, you gotta have spark plugs!
  7. 41bigdawg
    41bigdawg Let the Big Dawg eat !
    Portland, Tennessee
    2007 Big Dog K9, 2012 Heritage Softail, 2018 Honda 250 Dirt bike
    Robert
    I run the E3's in all of my bikes and they work great :chopper:
    You can get them from Curits @ Wildsteedworx.com
    #7 41bigdawg, Feb 11, 2019 at 3:33 PM
    chubs likes this.
  8. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    I used to run Champions, then I had a fouling issue because of EFI system and o2 sensors.
    To keep it riding during diagnosis and repair time I happened to try e3-36 plugs.
    I went from fouling out plugs in under 300miles to not fouling them out at all.
    After that, even after replacing O2 sensor, I never went back to champions and probably never will.
    41bigdawg likes this.
  9. roadie1389
    roadie1389 Active Member
    Wylie, Texas
    I tried the E3 in a lawn tractor that had a leaking valve guide and it did not foul out anymore. Ran the engine for about 2 more yrs after that, then go a new Zero-turn. They do what they claim, but I run the NGK iridiums in all my bikes, That's what I like.
    chubs likes this.
  10. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    I ran the NGK iridiums for a very short period years ago in my BMC Chopper -- Plus only lasted a couple of week on one cylinder -- damn electrode was GONE when I pulled the plug -- never considered them again.
    Glad to know they work for somebody.
  11. heybaylor
    East Texas
    Carl
    opinions, everbody has one , that's why the sparkplug business is flourishing :smash:
    chubs and 41bigdawg like this.
