Spark plugs
Discussion in 'Technical' started by lee, Dec 23, 2008.
  1. oldmutt
    oldmutt Active Member
    Central New Jersey
    08 Mutt
    Mike
    I have 11K on my mutt and I change plugs at 2500 miles along with the oil. The champs are $1.99 each at Auto Zone. If I can pay $11 a quart for amsoil I can afford new plugs.
    dentdude36 and chubs like this.
  2. HuskerChop
    HuskerChop Member
    Live Grand Island, Ne, work in Rocky Mountain Area
    07 BDM Chopper, 14 Street Glide, Wifes 13 Street Bob
    What the hell, I will throw my 2 cents in on this! I raced late models (VP Fuel) and sprintcars (Methanol) and Spanel Engines and Gaerte Engines built all of my motors. Racers are notorious for 'monkey see, monkey do' On both motors, latemodel 358 cast iron Bowtie heads and Sprint 360 aluminum heads, on the dyno, sequential pulls we compared champion vs NGK. I was surprised at results. Each spark plug change between the 2 had indexing and reach shimmed to be almost exact. On cast headed motor, champion plugs were 1.2 hp, 2.1 tq better, on aluminum headed sprint, the NGK's were the better by about same amount than Champion. Total of 4 pulls on each chg. Results were repeated. I run NGK DCPR7E in my Chopper, about $2 bucks and chg each season.
  3. Vince81
    Vince81 Banned
    Huntington Connecticut 06484
    3 Big Dog Pitbull kits-built myself & 11 other Custom Motorcycles
    Vince
    I change the plugs in my bikes about once a month or maybe every 10 to 12 hours of riding on my street bikes - sometimes even more often than that.
    Spark Plugs are cheap and it's just a regular maintenance habit of mine to grab a new set every time I clean or go over that particular bike I'm riding that day .:D
    Grab em ,gap em , install em and grab a glance at the old ones before I chuck em in the garbage.
    Vince
    Jgroth41 and chubs like this.
  4. stinger1
    stinger1 Member
    london england
    2005 bulldog - 69 camaro
    micky
    I found my dog runs better on NGKs....
    chubs likes this.
  5. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    NGK DCPR7E @ $3.80 per pack of 10
    Pack of 10 NGK DCPR7E spark plugs for $3.80 !!!
    [ame=http://www.amazon.com/SPARK-PLUG-3932-Pack-10/dp/B0025QVT6G/ref=sr_1_7?ie=UTF8&qid=1343304686&sr=8-7&keywords=ngk+dcpr7e]Amazon.com: SPARK PLUG # 3932 , Pack of 10: Automotive[/ame]
    But.... why when checking if it fits BDM models in the page it says "IT DOES NOT FIT"?????? What you reckon guys? In the page it states they are DCPR7E s, so..... :confused:
    Also, what is the difference between DCPR7E and DCPR7ESFP
    Your inputs, please?
    #25 francoblay1, Jul 26, 2012
    chubs likes this.
  6. francoblay1
    K9 (2006)
    Franco
    I've waited for over three hours for some feedback and nothing....
    Decided to buy the NGK DCPR7EIX (Iridium) :D
    chubs likes this.
  7. bigdog2003
    bigdog2003 Member
    2003 Big Dog Chopper
    A 107 is basically an Evo. I use Champion RN12YC in mine and it runs great. $2.50 a piece at my local bike shop.
    chubs likes this.
  8. bigdog2003
    bigdog2003 Member
    And ... don't forget the anti-seize paste.
    chubs likes this.
  9. BigDogBro1
    BigDogBro1 Made in the USA
    Near Hell MI
    07 Bulldog, full chrome, Pergy w/gold leaf paint, V&H BR pipes, Gator & Ostrich seats
    We run Champion plugs with the smaller hex nut pattern using a 5/8" wrench. RA6HC?
    Much easier to install and remove.
    #29 BigDogBro1, Jun 28, 2013
    chubs likes this.
  10. Jgroth41
    Jgroth41 Member
    Troutdale oregon
    2004 big dog mastiff
    John
    So i pulled my plugs today and i have autolite AP65 plugs..does not cross referance with anything plus they are a 14mm thread..Im told i need a champion RA8HC, N12YC or a Auto lite 4164...all of these are 12mm threads..Did the previous owner screw up ?.. Will i be able to put the proper plugs in?.. Im very concerned
    chubs likes this.
  11. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Those are right for the 04 and older engines you are fine.
    The quoted 12YC are for 04 and earlier.
    Engines went from the S&S Super Sidewinder (SSW) to the S&S Super Sidewinder plus in 05 (SSW+). For some reason they went to a smaller plug along with a few other changes cam to crank sensor and new breathing
    #31 Th3InfamousI, Feb 22, 2016
    chubs likes this.
  12. Jgroth41
    Jgroth41 Member
    Troutdale oregon
    John
    chubs likes this.
  13. Jgroth41
    Jgroth41 Member
    Troutdale oregon
    John
    Are the 12YC 14mm ?... the champions i just bought (RA8HC are to small..they just drop in..
    #33 Jgroth41, Feb 22, 2016
    chubs likes this.
  14. Jgroth41
    Jgroth41 Member
    Troutdale oregon
    John
    I found it..thanks
    chubs likes this.
  15. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    If your bike is jetted & timed right, you can run 20,000 + miles on a set of plugs, no problem.
    Check them occasionally for build up of residue. If there's any, you need to change them. If the electrode is burnt, and really rounded, same deal.
    John
  16. Jgroth41
    Jgroth41 Member
    Troutdale oregon
    John
    Thanks Man, I just put in the new ones..it back fired when i first started it but ran good..I might have to tighten the plug gap a little..im at a loose 40
  17. john sachs
    Deltona, Fl
    harleys
    I like .035", unless the compression is over 11.5:1. Then I'll go to .032".
    Be sure when replacing the plugs to make them tight. I can't count the # of bikes that come into my place with plugs that aren't as tight as they should be.
    I tighten the new plug with a drop of oil on the threads, back off, and re-tighten them tight.
    John
  18. Jgroth41
    Jgroth41 Member
    Troutdale oregon
    John
    Thanks..I will try .035
  19. MossBerg590
    MossBerg590 Active Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    Do you torque them John? I always just tighten by feel but am skeptical to over tighten.
  20. Jgroth41
    Jgroth41 Member
    Troutdale oregon
    John
    Update..for shits and giggles i set the plugs at .038..Big difference than .040..more power ..Tomorrow i will try the 0.35 and see how that goes.
    dentdude36 likes this.
