Starter Issue
Discussion in 'Help Wanted' started by Hector Lopez, Jan 2, 2018.
  1. Hector Lopez
    Hector Lopez New Member
    1800 Killian lakes dr apt 83201
    2004 Big Dog Chopper
    Hector
    chubs likes this.
  2. KnotSo
    KnotSo Admin
    Washington
    Nukeranger, chubs and Hector Lopez like this.
  3. Hector Lopez
    Hector
    Thanks
    Sent from my SM-N950U using Tapatalk
    chubs likes this.
  4. pauldeepsea
    pauldeepsea Well-Known Member
    California
    Paul
    I think your jackshaft it broke or may be loose. Make sure the bolt is tight and seated. If it is tight remove your starter jackshaft to see if it is snapped. Really easy to do and plenty of diagrams to show the internals. I am in no way trying to undercut our vendors but it’s a pretty simple fix.
    If you have anymore questions pm me your number and I will walk you through it
    Hector Lopez and chubs like this.
  5. pauldeepsea
    California
    Paul
    What year bike? It looks prior to 05? I will recommend going with an ultima starter. I have now ties to ultima just 2 bikes that I use them in and by far have outperformed more expensive staters that I have used.
  6. Hector Lopez
    Hector
    Bike is an 04,
    Thanks
  7. Hector Lopez
    Hector
    Thanks for the advice I will check.
  8. pauldeepsea
    California
    Paul
    Any luck?
  9. Hector Lopez
    Hector
    I took it to a local starter/alternator shop and the gentlemen said it was the clutch. He fixed it. I installed the starter and seems to be working fine, however, since is a 2004 I'm thinking I will upgrade to a newer starter soon anyways.
  10. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    No need for an upgrade on an 04, thats a standard Harley starter, no upgrades were made until 05 and up ..
    Hector Lopez likes this.
  11. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    You should check THIS out!!!
