Thanks Neil, I read the thread you wrote, I have experienced a similar situation with a 2-stroke YZ 400 i own. I had just replaced the piston and rings so the compression was at its peak. Well a weak throttle return spring didn't allow the throttle slide to return down when you opened it up. THere was so much vacuum through the carburator that the slide wouldn't fall. So my YZ 400 is running wide ass open and not stopping. I clutched and stopped. The kill switch wouldn't stop the engine, so last ditch effort, i pulled the plug wire. That is when i freaked. The motor kept running, vacuum pressure holding the throttle slide open and diesel effect burning the fuel. Last ditch effort was closing the choke. That killed the run away YZ.
I will pay close mind to the starting of the K9 over the next few weeks and see if there is any correlation to being warm.
I did luck out in my repair bill, instead of a $425 new starter, I was able to find a jack shaft that matches the one I broke at a local starter/altenator shop and only paid $10 bucks for the shaft, a buddy with a bike shop put it in my starter for me, so all I have left to do is put the starter back on this weekend. I do intend to drain the primary and remove the cover for a good inspection of that side since my dumbass push started the bike and rode it home with the broken shaft and gear bouncing around in there. I won't ever do that again, if the Bigdog won't start get the trailer! Thanks for the information, I have learned alot about my bike this week and got lucky it didn't cost me alot. Hell only 58 payments left and that beauty is all mine. Hahaha
