Starter spinning?
Discussion in 'Help Wanted' started by cavcom278, Jun 8, 2018.
  1. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Simple fix..
    BWG56 likes this.
  2. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    Yes great customer service ! Dereck saved me 400 $ with his advice on a repair rather than buying a new part from them :old2:
  3. Sven
    Sven Well-Known Member
    building one
    My guess would be import vs US made and the heat treating process is not third world but more like 2.0 kind of almost there.
    And the raised compression part I'm confused about. Nature filling a void is all even @14.7. Same number if the bike was not started and there sits the same number still @14.7. If you ever played with vacuum gauges that read in these units of pressure, the needle locks to 760mmHg. This is occurring under sustained speeds. If the bike is turned off, that vac gauge needle sits @0. If I WOT the throttle, that needle moves right back to 0.
    So unless you can explain MORE AIR entering the chamber, or was this more a SPEED EVENT occurring the more you open the throttle. I have to assume the same number closes on the intake valve no matter the rpm, but the 'air entry' happened faster was all. Make any kind of sense?
