Starter test
Discussion in 'Technical' started by Lowgear5, Mar 19, 2012.
  1. Lowgear5
    Lowgear5 New Member
    Broken Arrow, OK
    2004 chopper
    Travis
    I'm having trouble with my Chopper with what appears to be electrical issues (go figure, a BigDog with electrical issues). I bought my bike brand new in the Summer of 2004 and for the first 12-16 months I had nothing but Hell (which sounds like from reading threads, insn't uncommon). I had the ECH changed (while still under factory warranty) and that corrceted a lot of issues for a while. It wasn't until I changed the ECH myself with the upgraded computer that she actually ran better than she ever did before. I rode it for several years with the normal maintenance needs until recently. I try to start the bike and the compression releases engage, release and then nothing else. I ran all the traps, checking voltage to the appropriate wires and I got to he starter. I've taken it off and thinking I could test it by supplying a charger to the possitive and negative lugs on the starter to see if it would engage. When I did, nothing. With the starter on a work bench, shouldn't this engage the starter as it would a car or am I missing something? ( During the multiple replacement of parts during the warranty period, the starter was replaced with a higher
    torque starter, so ths is not the original starter than came with my bike. Thanks in advance for the input.
    chubs likes this.
  2. stlmikie
    stlmikie I wish I had more money.
    St. Peters
    03 Mastif
    Mike
    Check out this video on YouTube:
    [ame=http://www.youtube.com/watch?v=AWSm_GH52g8&feature=youtube_gdata_player]How to bench test a starter motor - YouTube[/ame]
    Sent from my iPhone
    chubs likes this.
  3. Lowgear5
    Lowgear5 New Member
    Broken Arrow, OK
    2004 chopper
    Travis
    If I understood the video correctly, it looks like applying the elextric supply to the lugs it should activated the starter's cylinoid switch. I could always tell from the video but is that what you took from the video?
    chubs likes this.
  4. Little-Boo
    Little-Boo Well-Known Member
    Lifetime Supporting Member Supporting Member Troop Supporter
    McAllen, Texas
    2013 Tri-Gluide, 2006 Mastiff, several Mods to many to list
    Carlos
  5. Lowgear5
    Lowgear5 New Member
    Broken Arrow, OK
    2004 chopper
    Travis
    Sounds like i need to tear into my starter and clean the intrnal contacts. I believe that is the next logical directon to go with my starter appearing to play "possum"
    chubs likes this.
  6. Blake johnson
    Blake johnson New Member
    Pocatello idaho
    2005 ridgeback
    Blake
    This is Blake Johnson yeah I'm in Brandywine Maryland I'm looking for someone that can rebuild my starter anybody got a clue
    Sent from my SAMSUNG-SM-J120A using Tapatalk
    chubs likes this.
  7. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Hey learn to read...he's looking for someone to rebuild his starter..:crazybitch:
    chubs likes this.
  8. bdm7250
    bdm7250 Guru
    Doug
    :agree:On the local starter shop..:old2:
    chubs likes this.
  9. KnotSo
    KnotSo Admin
    Washington
    chubs and Reddickracing like this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Make sure it has the correct gear on it, correct gear is on the left. Some have been rebuilt with the wrong gear.
    bdm7250 likes this.
