Starting problem
Discussion in 'Technical' started by brucetowne, May 25, 2018.
  1. brucetowne
    brucetowne New Member
    US
    Fuel is good.
    Spark is good.
    Won't fire. An occasional backfire only.
    Crank position sensor?
    Sent from my SM-G928V using Tapatalk
  2. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    You take the air breather off and see if it is actually getting fuel in the carb?
  3. brucetowne
    US
    Yes I did. Sprays from accelerator pump nozzle perfectly
  4. pknowles
    virginia
    paul
    And both sprak plugs showing fire?
  5. brucetowne
    US
    Yes they are but I'm going to verify that again this afternoon. The gas is also fresh and the enrichener is also working.
  6. pknowles
    virginia
    paul
    I= I would try it without messing with the enrichner if you are getting a good spray in the carb
  7. brucetowne
    US
    It seems that the plugs are not firing at the right time. Not sure what the crank position sensor does or if affects ignition timing.
  8. pknowles
    virginia
    paul
    Do you need a manual
  9. brucetowne
    US
    Yes and it would be helpful. The one I have is incomplete.
  10. brucetowne
    US
    I have a 2007 K9.
  11. Sven
    Sven Well-Known Member
    Full Member
    building one
    Change spark plugs. You've got nothing to lose. And the battery is well charged, right?
    Signed,
    NOLTT (no one listens to turtle)
    pknowles likes this.
  12. chubs
    chubs Guru
    Full Member
    indiana
    2002 pitbull Prostreet --
    runky
    Suddenly start acting up, or was it running poorly prior to this ?
  13. pknowles
    virginia
    paul
    Do a
    Search for member broadband. He has a link posted to a dropbox where you can download the manual.
  14. brucetowne
    US
    Plugs are new. A sudden problem. Finally cleaned it up to start riding. Ran great at the end of last season.
  15. chubs
    chubs Guru
    Full Member
    indiana
    runky
    Single fire or dual fire coil ?
  16. brucetowne
    US
    Stock coil. Single fire,
  17. Sven
    Full Member
    building one
    [QUOTE="brucetowne, post: 861198, member: Ran great at the end of last season.[/QUOTE]
    Fresh gas in the tank maybe, but not in the carb bowl. Trying to start a bike with stale gas? The bowl needs to vent so that vapor left months ago [sitting]. So the plan would be to drain the bowl, turn the petcock on and let it flush the rest out and then close the bowl screw. The mixed gas might start it. Shelf life wise, today's gas goes bad in about 9 months. Yes it's still volatile and will burn with the new gas no problem.
