Swirl remover for paint?
Discussion in 'Show & Shine' started by AndrewWilker80, Nov 1, 2018.
  1. AndrewWilker80
    AndrewWilker80 New Member
    AZ
    Andrew
    Hi everyone, I stepped in to ask a quick detailing question. My Dog has got swirls on paint, looks like it was polished when it was dusty, you know. Small scratches that are invivsible when it gets darker, but they are so visible when the bike gets direct sunlight. I do not feel like repainting that part or polishing it not to make that paint coating even thinner. I saw swirl removers online, but the descriptions say that the liquid removes swirls, and does not say exactly how it works.
    I wanted to ask you folks please explain thi sto me, as if this thing works just like any other adrasive and just polishes scratches off, that's not something I want to try. Yet, if the formula fills in those scratches with something and kinda hides them for some time until it gets washed out, I'd like to see how it works.
    Appreciate your help...
    Andrew
  2. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    paul
    If you do a search in the show and shine section, there is a ton of information on cleaning and polishing.
  3. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    You have to polish out swirls. Only way. Use an orbital buffer. The harbor freight one is pretty good for $60.
    PacoPetty likes this.
  4. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Use this
    Followed by this
  5. pknowles
    virginia
    paul
    AndrewWilker80 and bdm7250 like this.
  6. Sven
    Sven Well-Known Member
    building one
    A pro painter said the trick is to melt the clear coat. He then took his high speed buffer to my old fiberglass tank and it came back from the dead. The polish is just the lube for friction, right?
  7. Reddickracing
    Reddickracing Active Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    1800 rpm, and dark foam waffle pad, and purple bottle 3M polisher (either the one Doug suggested or 3M 06064 both are good), Damn near get a dent out! lol
  8. PacoPetty
    PacoPetty Well-Known Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    Big D Florida and bdm7250 like this.
  9. bdm7250
    bdm7250 Guru
    Doug
    Yep, came to me from the mouth of the shine master.. :old2:
    pauldeepsea and PacoPetty like this.
  10. PacoPetty
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    Then it is the gospel!
  11. AndrewWilker80
    AZ
    Andrew
    I appreciate your replies, folks. I thought of polishing out the swirls, and I appreciate the recommendation on the 3M compound & finish and Canuba wax, I believe that's what I will be using on my bike then.
    However I saw those 'swirl removers' and thought maybe they will allow removing swirls by filling in the spaces between the minor scratches. I've tried looking through reviews and stuff, and couldn't find any info on swirl removers except of the polishes. Seems like I'm lucky that I've posted here, as I was about to pick a bottle of this Cycle Care stuff (Link), as I was under impression this liquid was going to fill in the scratches, as I said.
    I guess I will be using the combination of 3M and Canuba wax then... If everyone says this is a great combo.
  12. pknowles
    virginia
    paul
    Morning,
    Show us the results:oldthumbsup:
    AndrewWilker80 likes this.
  13. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    Wizards Shine Master
  14. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    Sutton
    I do not like wax. It comes off immediately. So many better sealants out there now with new chemical technology. I use an SIO2 ceramic sealer after I do any paint correction. It'll last 6+ months on my cars, forever on the bikes and hot rod. I use the Menzerna 3000 polish. It'll get out the spider web swirls you're talking about. Anything heavier is too much. Use a foam pad and buff it with an orbital set on 3 until it's totally clean. Then apply the gtecniq Crystal Serum lite by the directions. If you don't want to do a full ceramic job, the P&S Bead Maker is an excellent top up type spray. Spray it on the clean paint after the correction is done, sort of wipe it 'in' and then buff it off with a dry towel (only use microfiber). Let it 'cure' for 8-10 hours DRY (don't get it wet, you'll drown the polymers and silicone particles). Then re-apply again to sort of build it up. After the first application you'll come out and notice the bike has a deeper shine to it as it cures. From here on out only use the P&S as a detail spray, it builds on itself. You can wash the bike if you get it really dirty. A gallon of P&S is about $32 shipped from PDT detail suppply. That'll last FOREVER. I use 4-6oz on my cars. A bike takes a tiny bit. You can apply it to chrome/billet too. Does a great job of keeping things clean and making them easy to clean.
  15. geoffmt
    geoffmt Member
    Billings, mt
    07 bull dog efi
    Geoff
    I use the mcguires DA with their pink correction compound, then a polish. Comes out perfect without burning the clear
    PROFLYER likes this.
  16. Letbigdogintocanada
    Letbigdogintocanada Active Member
    04 bulldog 09 streetglide cvo
    Junior
    Get a good DA buffer and a good compound I use HD speed all in one,should take em out or just take it to a good detail shop,good Luck
    #16 Letbigdogintocanada, Nov 3, 2018
  17. AndrewWilker80
    AZ
    Andrew
    Sure thing, and I will let you folks know, what products I will be using....
    Appreciate all your help and recommendations!
