Tear down
Discussion in 'General' started by bigkelk9, Oct 4, 2017.
  1. SomeTexan
    SomeTexan Member
    Godley Tx
    05 Big Dog Ridgeback
    Adam
    From what I’ve been reading, the 585 is great if you aren’t upping compression. It has less overlap giving you more dynamic compression. Now, if you cut the cylinders down and run the 585 you may have pinging issues due to the lack of overlap. With the raised compression, the 600’s extra overlap brings the dynamic compression back to a safe level for pump gas, and makes use of the extra static compression with more lift/duration.
    bigkelk9 likes this.
  2. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    There may be something there, I know shit but I remember few years back in AR when it was seriously hot, I rode a long day and have shaved cylinders and 585, I had to kill the engine with gear... bloody diesel K9.
    Andy, should I now go 600 after your mods too?
    SomeTexan likes this.
  3. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    ....I said he would have to cut the cylinders if he wanted to go with a 600. Since he already boxed them up and never measured the deck height it's a little hard to cut them when he doesn't know by how much.
    Post #9
    #43 Th3InfamousI, Oct 11, 2017
    PROFLYER likes this.
  4. SomeTexan
    SomeTexan Member
    Godley Tx
    Adam
    That sounds about right. If you could have pulled a degree or two of timing, it probably would have helped. Although these big twins aren’t my area of expertise, cam theory is the same for all internal combustion engines. I was actually shocked at how few cam options there are. I’m used to Chevy big and small blocks that have literally tens of thousands of options available. Woods has some neat cams, but most of the ones I have looked at have some pretty aggressive ramp profiles. Mix that with the offset rockers on these big bore engines, and you have potential problems. Mainly just excessive wear, but aggressive ramp profiles are harder on springs, pushrods and valves and seats as well as the rockers. Most of the S&S cams seem to be fairly gentle on the valvetrain though.
    I could talk cam theory all day, but it looks like you have a pro who knows his stuff handling your parts. Let him know what you want and take his advice.
    TapioK and PROFLYER like this.
  5. SMCT
    SMCT Active Member
    North East
    06 K9, H-D Dyna Wide Glide
    Andy
    These pistons are .048 to .052 in the hole. That is ridiculous. There are some serious gains by reducing the piston to deck clearance and tightening up the quench. From memory these engines in the Big Dog frame as they came from Big Dog are 9.52 with a .039 gasket. By bringing the deck clearance to around .005 rather then .052 and using a .035 gasket, it drives that compression ratio to 10.77, and with the 600 cam and premium fuel, they do just fine. It's the camshafts intake events that bleed off the cylinder pressure, and as always your camshaft events should match your compression ratio.
    Steve2134 likes this.
  6. SMCT
    SMCT Active Member
    North East
    Andy
    Tapio, your heads and cylinders where in my shop, although I did not have your short block in my shop. When we spoke, you mentioned to me that, "you think that they might have been cut, but wasn't sure". When I picked up the heads and cylinders, your k9 was already at your local motorcycle shop. I never cut your cylinder bases.
    To answer your question, I would definitely need to know where the piston sits in relation to the top of the cylinder when the piston is at tdc. This can simply be done by removing the front cylinder head. You can re-use the Cometic gasket that is on your engine.
  7. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Just for future reference, when you see something posted by SMCT, you stand at attention and listen to what he has to say. This man knows what he's talking about. :old2:
  8. SomeTexan
    SomeTexan Member
    Godley Tx
    Adam
    Did you catch the last paragraph in that reply? Not many people get the “pro” title and even fewer get the straight up “take his advice” recommendation from me. Even fewer that I don’t personally know get that recommendation. There is a lot of respect from me in those two sentences.
    chubs, bigkelk9 and Mr. Wright like this.
  9. Th3InfamousI
    Texas
    In with ya...tighten up the quench. Hopefully some day I'll do that.
    These S&S motors we have are EPA so they did detune to pass them.
  10. Th3InfamousI
    Texas
    I'm guessing you use the MLS Cometic Gaskets?
  11. SMCT
    SMCT Active Member
    North East
    Andy
    I am on a deep discount with Cometic and the head and base gaskets for these S&S engines are cheap in comparison to what we use in the shop, so I bought a bulk of different head gasket thicknesses. The base only is offered in one thickness which is .019. That will allow those who don't want to take the cylinders up and off, to just replace their current .039 head gasket with a .023 or a .027 head gasket.
    It wasn't a thing about making a business out of it, or making money on it. It was more or less that I could help others with their problems and frustrations, and have the parts to ship to them if need be. These engines are quite simple. Not to much to them. One simple philosophy and you'll be on the right track and enjoying these motorcycles. They are stunning looking bikes, and once you get a few things taken care of (faults of poor engineering decisions) you will be very pleased.
    If you haven't changed out the factory gaskets at this point, you will be. The factory garbage base gasket tends to blow out and distort (Oil leak at cylinders base). It's apparent that any way Big Dog could cut corners, they did. Very unfortunate.
    #51 SMCT, Oct 13, 2017
  12. Butch Cassidy
    Butch Cassidy Active Member
    Fate Texas
    2000 Bulldog
    BUTCH
    Okay; I have a 2000 Bulldog with a 107" and a 600cam. Should I be looking at a base gasket change and/or a tighter quench.? Any problems I should expect.?
  13. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    So just an update, spoke with the machinest and my cylinder walls were out of round so they had to be honed which of coarse New piston and rings. The heads were on such bad shape that the sleeves were stuck to the valves and coming apart. So needless to say, the original 400 to 600 I planned on spending has now turned into 1400.. but he says I should have 60 to 80k engine trouble free miles from it, being my bottom end is all New as well.. and decided on going with the 600 after I found out that the 117 came with them stock and were pre shaved unlike our engines that had to be EPA approved.
    BWG56 and TapioK like this.
  14. bigkelk9
    07 big dog k9
    Kel
    Yeah.. well between that, both compression release wires solder being broke, which explains how I went through two starter shafts in less then 6 months. And them damn things were loose too.. at least I know it will be solid when I get everything back. I would have never thought it was that bad with how much I ride it and all that.
  15. bigkelk9
    07 big dog k9
    Kel
    So just spoke with three different powder coating places and was told the same thing by all three, the machine work should have been done after powder coating due to oven temps and making sure the metals are true after.. I mean it's only about 150 worth of powder coating to do the whole engine, but they have to split the case of the engine and press new bearings and blah blah blah which is like 500 bucks. So all and all I'm looking at about 1k for powder coating for them to recheck what was just done.
  16. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    and,,,,,,, with them splitting the case back open, there goes your warranty.
  17. bigkelk9
    07 big dog k9
    Kel
    These things have some kind of warranty?? Whaaat?? It's like 10 years old.. :eek:
  18. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    the 30 day warranty from the shop doing your work. (yea, right)
  19. bigkelk9
    07 big dog k9
    Kel
    They aren't touching the bottom end. The bike is at my house, I took the top end off and shipped it off to get all that done.
  20. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Remember Kel, bigger is not always better! Haha!
    BWG56 and bigkelk9 like this.
