Tear down
Discussion in 'General' started by bigkelk9, Oct 4, 2017.
  1. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    What's the word on you motor, any update?
    bigkelk9 and dentdude36 like this.
  2. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    No verdict yet aside from all of my sources telling me the wrong torque specs.. lol.. I haven' had a chance to even take the p pad off from the rally.. she is still sitting where I parked her after the rally..
    fiftyonefifty5150, chubs and BWG56 like this.
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Do ya have any idea where the ticking is coming from?
    dentdude36 likes this.
  4. bigkelk9
    07 big dog k9
    Kel
    What explanation of the push rods? As to why one had more thread showing then the others?? Idk.. did it 4 times which was very time consuming and got the same result every time..figured if something was wrong I would have heard it right away.. instead she fired right up and rumbled
    chubs likes this.
  5. bigkelk9
    07 big dog k9
    Kel
    So a bit of an update, after many different responses and so on I spoke with S&S and Cometic to get a straight answer because some are saying just re use the gaskets and just re torque to many different specs.. Cometic claims they test torque specs and stress points on many different engines and assure me that I'll be fine if I use their specs which are a 5 step process which is a slow and gradual torque. They also claim that if I don' use their specs my gaskets will never seal. So I ended up speaking with an engineer at s&s and he claims I should be fine and to use their specs. So I ordered new gaskets and I will use the specs they give me when they get here and let you all know how it goes.
  6. chubs
    chubs Guru
    indiana
    2002 pitbull Prostreet --
    runky
    I have no clue what it would be, but if it works, it must be okay. Sweet ride ! !
    pknowles and bigkelk9 like this.
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Maybe the ticking you hear is the head gasket leak
    bigkelk9, pknowles and dentdude36 like this.
  8. bigkelk9
    07 big dog k9
    Kel
    No sir.. it's in my rocker boxes which I have a fix for. So I should be gold when this is all said and done.. it' just a waiting game now broham
    john sachs and BWG56 like this.
  9. bigkelk9
    07 big dog k9
    Kel
    Round 2..
    cdogg556 and john sachs like this.
  10. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    He was afraid he would break it..cant break it if it was already broke...ha
    cdogg556, bigkelk9 and dentdude36 like this.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Blame Cdogg if it exploded, brilliant:(
  12. Th3InfamousI
    Texas
    Oh yea! I'd send John the bill!
    cdogg556 and bigkelk9 like this.
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    There not, well not supposed to be, but if they were he would have valve damage.
  14. Th3InfamousI
    Texas
    He installed them here originally had the quickee Rods so 2 long and 2 short.
    Longs in the front shorts in the back. Not sure how he installed them this time though, I didn't see this project.
    bigkelk9 likes this.
  15. bigkelk9
    07 big dog k9
    Kel
    So just an update, used a torque wrech to loosen the bolts to verify my torque which I did after I torqued them originally.. torque wrench set at 36 didnt snap once loosening the bolts up. One was finger loose. Gaskets not blown, just all leaking badly.. as far as the push rods go, the front intake was threaded less then the rear.. no one knows but it ran great for 100 miles, still ran great when I took her apart.. just leaking oil.. lol.. I'll throw the push rods in in the morning and do the adjustments and keep y'all posted
    Unsprung likes this.
  16. pauldeepsea
    pauldeepsea Well-Known Member
    California
    Paul
    Is this your first S&S rebuild?
    I am considering rebuilding the 107 , but the motor is one thing I don’t have experience on and really don’t want to f it up. I have tore a few down to the pistons but had a shop finish it. Just wondering on the difficulty?
  17. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Hahaha! I putted it round da block, the only thing I can get blamed for is going to slow! :)
    BWG56 and bigkelk9 like this.
  18. bigkelk9
    07 big dog k9
    Kel
    Yeah, my first rebuild and actually very very east.. just should have followed my instincts on torque specs is all.. next time I'll fallow my gut for sure.. being an ASE mechanic for many many years I knew better to increase the torque in slower increments to crush metal gaskets to actually seal.. I'm sure u will be just fine. The know how was well worth every minute and the power will be well worth the money..
  19. bigkelk9
    07 big dog k9
    Kel
    Okay, so after throwing new gaskets in her, following the Cometic torque specs and installing a new starter she seems good to go..
    cdogg556 likes this.
  20. Brandon Downey
    Brandon Downey Active Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    The second time he started it, that's what mine does sometimes. Kind of has to grunt through a cycle to get her going. I still have to check my battery though.
