Tear down
Discussion in 'General' started by bigkelk9, Oct 4, 2017.
  1. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    No the rocker lockers are tapered bushings that go inside rocker box bolt holes and take up the gap between the bolt and notch in rocker shaft.
  2. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Not sure why you say that, They are notoriously noisy.
    I have mine out and the shaft bushings are fine, but there is a lot of play between the notch in shaft and the bolt.
    Mine sounds like crap, I can’t stand it.
  3. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Weird forum is causing problems on tapatalk and double posting so I tried to delete.
    How do you know the shaft bushings are fine? Also that could just mean the shaft is worn.
    Lots of guys with lots of miles...60k plus and no lockers. And I can't find any that fit S&S anyways, then all state Harley. Also the issue was really came to life on the twin Cam Harley's and we don't even have that motor. Maybe John will chime in if he is using them on S&S and where to source.
    Take a look at Marky Marks video on this should help explain a little better with a visual. I know this is a TP engine but same is possible with S&S
  4. Th3InfamousI
    Texas
    Also note the S&s manual the bushings are in spec between 0.5546" - 0.5559". That's only 13 thousands of an inch!
    That's why I asked how do you know they are in spec? I know I don't trust my calipers to measure that small I got a cheap set.. Haha
    #164 Th3InfamousI, Feb 6, 2018
  5. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Idk.. but what I do know is I waisted almost 2k.. I would not recommend the guy that did the work to n e one and now I'm screwed do to unforseen financial circumstances. I mean bike runs great, just a noisy bastard and I'm not cool with that..
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :oldnono: .0013 is not 13 thousands, its 13-10 thousands
  7. Th3InfamousI
    Texas
    Well good news is shaft and bushings are only about $60 total and if you take it down to your local shop guy have him install the bushings and ream them with the $200 tool your only out about $60 plus whatever be might charge for the bushings gotta be no more than 30 min
    Unsprung likes this.
  8. Th3InfamousI
    Texas
    Haha ..right even worse! I wrote it wrong!! That's cause I was thinking of my cheap ass Harbor freight and it doesn't even measure past thousands of an inch
    #168 Th3InfamousI, Feb 6, 2018
  9. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Be interesting to hear what John Sachs has to say, I would get a set.
    dentdude36 likes this.
  10. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    You have a point, I was simply going by how loose they felt, and my Conversation with John, and also a lot of info out there on the Harley's. They designs of teh rockers are all essentially the same.
    I want to address it while I have mine tore apart.
  11. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    Met him last bikeweek he definitely knows his stuff good dude
    bdm7250 likes this.
  12. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    It's my understanding that the 117 is already hopped up by s&s specifically for big dog back in the day so why push it further???
    bdm7250 likes this.
  13. bdm7250
    bdm7250 Guru
    Doug
    :agree::stupid: I was with you..:skep:
  14. Th3InfamousI
    Texas
    It's worth a thought, cause if the bushings are out of spec the rocker lockers wouldn't quiet it down necessarily.
    And like I said I'm curious what John uses looking at Rocker Lockers and Rock Out website just states "harley" so I just don't know if the Bolt are the same size between Harley and S&S.
  15. bdm7250
    bdm7250 Guru
    Doug
    Because the possibility is there..:yesnod:
  16. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    I mean really how fast do ya need to go!? These bikes already have gobs of power ahead of their time leave a good thing go
    bdm7250 likes this.
  17. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    It's all about making an EPA restricted engine more efficient. The after bonus is an increase in horsepower, torque, longevity.
    John
    bigkelk9, dentdude36 and bdm7250 like this.
  18. bdm7250
    bdm7250 Guru
    Doug
    Do you have an answer on the rocker lockers John?
  19. john sachs
    Deltona, Fl
    harleys
    I have to call them to find out if they're available for the S&S saddles.
    They sure work in the Twin Cams.
    John
    bdm7250 and dentdude36 like this.
  20. bdm7250
    bdm7250 Guru
    Doug
    Thanks John..:old2:
    john sachs and dentdude36 like this.
