Tools in your Tool Bag
Discussion in 'General' started by Jersey Big Mike, Jan 12, 2018.
  1. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Full Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    What do you consider the esstential tools to be carried in your bag?
    What size Allens, Sockets etc.
    I'm getting ready to re-do my bag for the spring and wanted to make sure I don't miss anything critical and I'll end up erring on the side of more rather than fewer tools.
    For example, I usually carry the 11/16 for clutch adjustment and a modified allen so I can adjust without exhaust removal.
    Also, since I leave them on the bike thru all conditions, has anyone else considered vacuum sealing them to prevent rust etc. It's not like I use them regularly. I'll leave the allen set loose for my harley friends who never seem to have tools!
    PacoPetty, chubs and pknowles like this.
  2. HMAN
    HMAN Just like to ride
    Supporting Member Full Member
    Ks
    Harry
    I have a set of HF stubby wrenches, a full set of Bondhus stubby allen wrenches, a schrader tool, pliers, vice grips, screwdriver, flashlite and tire gauge. My OG roll bag was collapsing so I stuck some 4" pvc in each end. Roll tools up in a rag and done. Oh, and a spare fuse.
    PacoPetty, chubs and john sachs like this.
  3. Jersey Big Mike
    Full Member
    Murrell's Inlet, SC
    Mike
    A shrader tool -- Have to add that, thanks.
    I looked at the Bondhaus stubby but I hate bell end allens, have never had good luck with them, but might go that route for the stubby end and use the ball end once everything is loose.
    I also carry a LiOn jump start set, spark plugs. some gas line (occansionally shorter gas line and couplers) hose clamps, locktite (blue) Silicone stretch wrap/tape, electrical tape, paracord.
    My friends tend to think I go prepared and make boy scouts look like amateurs!
    PacoPetty, HMAN and chubs like this.
  4. Butch Cassidy
    Butch Cassidy Active Member
    Full Member
    Fate Texas
    2000 Bulldog
    BUTCH
    strap-on headlamp; tire repair kit (t-handles, strips, gorilla glue, 12v compressor), stand-up light/red flasher; pen-light; extra key; batt jump cables (for bikes); water-proof matches; fire starters; lighter; allen wrenches; shop rag; RV silicone tube; 15ft paracord; large + and - screwdrivers; extra fuel line and fuel filter; needle nose pliers with a curved nose (for removing nails in the tread); 1 qt oil; WD 40
  5. Jersey Big Mike
    Full Member
    Murrell's Inlet, SC
    Mike
    If I carried an extra key that would be wallet material not tool bag.
    Now we all know how to add a bulldog to our personall kennels -- goto texas -- open toolbag.... All kidding aside I'd move the key to the wallet -- take the exrta plastic off and it will fit in ok.
    PacoPetty likes this.
  6. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Here is my tool bag. I have changed the Allen to the ball end cause there's a few places it makes it easier.
    Socket is a deep 1/2" socket with a 1/4" drive that is in the event I ever got to remove my exhaust but I don't carry the drive figured I could buy it or someone may have one where ever I'm at (hotel)
    Axel, PacoPetty and Unsprung like this.
  7. Butch Cassidy
    Full Member
    Fate Texas
    2000 Bulldog
    BUTCH
    good point. I should have been more exact and said my extra key is on my dog tag chain. I have switched over my ignition to a 'round' key...
  8. Jersey Big Mike
    Full Member
    Murrell's Inlet, SC
    Mike
    You'd be surprise what AI have been known to carry.
    My first chopper, a BMC 918ST, is notorious for breaking primary belts. I now always carry one on the bike, since it has spoked rear 180 it requires a tube (not usually available at a shop), so I carry one. On my BMC I have 2 softtail toolboxes nad a roll bag full of stuff, including jumper cables (soon to be replaced by Lion jump system).
    I had a run years ago probably 06 or 07 where we were coming home and were in themiddle of nowhere South Jersey and when I pulled away from the light I felt the belt start to slip and I knew it was going to break, was in the back, got to third gear before it snapped. I had wanted to catch up so I could tell the crew to pull into the ice cream stop up the road -- didn't make it.
    One of the wives was following in her car and pulled over behind me and my tail-gunner went ahead to bring everyone back.
    I pulled the primary cover and the belt was shredded like cotton candy inside (mush to my crew's amazement)
    The response were primarily - "Oh, shit what are we going to do now" We're going to be here for a while"
    I told them all I need was maybe 15 minutes -- They scoffed.
    I cut the remaining old belt off the rear pulley, pulled the spark plugs, pulled the starter pinion gear off.
    I reached into my bag and pulled out the spare belt to resounding "Who the hell carries a spare belt?" to which I reply "Those of use that have had this happen more than once!"
    I got the belt around the rear pulley and got the front caught with a couple of teeth (crooked a little)
    Turn key, bump starter and the belt slips right onto the front pulley.
    I replaced the primary cover and spark plugs and we were off again in 15 to 20 minutes ( the biggest delay was waiting till engine was cool enough to work with!)
    PacoPetty, Butch Cassidy and chubs like this.
  9. Rottweiler
    Rottweiler Well-Known Member
    Elizabethtown, PA.
    2004 Chopper, 2014 HD Road King CVO, 1985 FXWG
    Todd
    I used to carry a spare EHC and my phone.
  10. Jersey Big Mike
    Full Member
    Murrell's Inlet, SC
    Mike
    Phone and AAA Plus RV (used that more than I care to admit too, last time was a broken clutch cable a couple of hours from home.)
  11. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    A cell phone and a couple of Allen wrenches, I have road side assistance.
    PacoPetty, Tomtang and chubs like this.
  12. Jersey Big Mike
    Full Member
    Murrell's Inlet, SC
    Mike
    ok, I've gotten a couple of good idea from some people of things I was missing.
    When I make the complete list of my tools I'll post it here (and show how much space it takes hopefully).
    I don't like being stuck waiting for AAA or other assistance especially if on a long run out of state.
    Last year I cancelled our trip to Rolling Thunder due to an oil leak in the return line -- Did a roadside (hotel) patch and went home instead of continuing -- should have trusted myself -- damn thing didn't lose any oil on the way home!
  13. Jersey Big Mike
    Full Member
    Murrell's Inlet, SC
    Mike
    Ok, my current list of tools to carry on the bike (after comments) -- PLease if you see anything missing you think I should have please say so (and no I'm not taking the kitchen sink in the tool bag).
    Allen wrenches -- full set sae
    stubby hex for clutch adjust
    combination wrenches 10mm, 1/4 - 11/16
    spark plug socket
    deep 1/2 socket
    ratchet
    pliers/vise grip
    adjustable
    Screwdriver straight/phillips
    flashlight
    lighter
    lion jump starter
    tire repair kit
    compressor
    shrader tool
    safety flare (led?)
    fuse
    gas line
    hose clamps (3 or 4)
    silicone stretch tape
    electrical tape
    spark plugs
    paracord
    electrical wire
    wd 40/silicone
    Blue locktite
    If space permits plastic drop cloth (normally for painting but good to keep you dry if you have to lay on wet pavement working on bike) only really need maybe 6x10.
    Oil pig rag (small section)
    Might add the 1 qt oil to this depending on space in the tool bag I am making, since I should have room. But I've never really had that big of an issue with oil on the Dog and even the BMC the only issue was wrong filter so it stayed in sump and blew out the top end (carb) and that happens pretty qucik so I'd likely not be that far from home/gas station/store etc.
    ANd no I am not contrary to the looks of things trying to duplicate my shop on the road -- I know thats not practical (yet) Still working ona design to jack up dog when on the road that would be carryable.
  14. Rottweiler
    Elizabethtown, PA.
    Todd
    Sounds great to me. The only thing I can think of quick is rubber caps for the carb. I guess you could just use electrical tape for that.
    Good job.
  15. Th3InfamousI
    Texas
    Oh yeah I have a small LED light too not sure why it didn't make the picture.
  16. Jersey Big Mike
    Full Member
    Murrell's Inlet, SC
    Mike
    EFI bike!
  17. francoblay1
    francoblay1 The Spaniard
    Full Member
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
  18. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    may have missed it, but, did not see zip ties listed.
    PacoPetty and Butch Cassidy like this.
  19. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    6" or 12"? :)
    PacoPetty and francoblay1 like this.
  20. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    if you need more than 6" you can put multiples together. and you can use that same answer in many different situations, lol.
