Torque specs
Discussion in 'General' started by Michael rogers, May 11, 2018.
  1. Michael rogers
    Full Member
    Massachusetts
    Mike
    I'm trying to figure out the torque spec for the primary screws
    Sent from my SM-G965U using Tapatalk
  2. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
  3. Michael rogers
    Full Member
    Massachusetts
    Mike
    Thank you
  4. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    Here is the torque sequence, Mike. Many guys like to clean the O-ring gasket and use a little red gasket sealer (thin layer) around it to make sure the primary doesn't seep.
    And another thing---unless you happen to have one of the billet primary inspection plates, it is folly to torque it to the specs cited because they tend to snap off a corner from time to time. I torque mine to 50, then 75-80 inch pounds and still manage to break off a tab every 30,000 miles or so. My next one will be the billet plates Donna and Derek sell.
    #4 SKOGDOG, May 11, 2018
    Hirter6Pack likes this.
  5. Michael rogers
    Full Member
    Massachusetts
    Mike
    Thank you I really appreciate the help
  6. Michael rogers
    Full Member
    Massachusetts
    Mike
    Thank you for your help . I did pick up the updated inspection cover because mine did crack
    pknowles likes this.
