TP to S&S Conversion . Have you...
Discussion in 'Motor' started by francoblay1, Feb 27, 2015.
  1. My bike came with S&S
    49 vote(s)
    44.5%
  2. Yes, I did the conversion
    17 vote(s)
    15.5%
  3. No, I am still with the TP
    40 vote(s)
    36.4%
  4. Why should I do the conversion ???
    7 vote(s)
    6.4%
Multiple votes are allowed.
  1. Olde Man
    Olde Man Active Member
    Fort Wayne, IN
    2006 K-9
    John
    I put the spacers in when I installed a 600 cam. I pulled the jugs to cut the bases to get the compression to 12.2 so the heads were off. That effectily made my pushrods .060 longer and I did not use lash caps. I know you are saying they are adjustable push rods so what is the worry. When I did my first prototype I made it .200 thick and with travel limiters in lifters the there was not a lot of thread engagement on the adjustable push rods. The .100 worked better for the geometry anyway.
    chubs likes this.
  2. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    You ran 12.2:1 compression with the S&S .600 cam ? What gas are you using ?
    If you raised the rocker box .100", what thickness lash cap were you thinking of using ?
    John
    chubs likes this.
  3. Olde Man
    Fort Wayne, IN
    2006 K-9
    John
    My bad on the compression ratio. It is 10.2 to one. I did this 01/27/10 and I got my motors mixed up. The 12.2 was the car in my avitar and I ran it on racing fuel then converted it to run on E85. I have never used a lash cap but when I was running out of push rod threads I was thinking of something like a .080 cap. When I went to the .100 spacer instead of the .200 it was ok. Did the E85 thing ever happen in the street bike world?
    chubs likes this.
  4. john sachs
    Deltona, Fl
    harleys
    Good, glad you figured it out.
    If you had used a .080" lash cap, that would have been the same (geometry wise) as reducing the thickness of your spacer by .080".
    I don't know of any bike builders messing with E85 .
    John
    chubs likes this.
  5. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    and two years later...
    Big D Florida likes this.
  6. IRONHEAD
    IRONHEAD Member
    Wentzville, Mo
    2006 k9
    Ed
    Ive got a 06 k9 that has the TP boxes on it and Ive had zero problems with them, but, I dont have a ton of miles on the bike.
    francoblay1 likes this.
  7. john sachs
    Deltona, Fl
    harleys
    Another 1 bites the dust. You can lead a horse to water, but you can't make him drink.
    You can't fool geometry. If you don't think you have a problem, sooner or later you'll get bit in the ass with TP rocker boxes on S&S heads/engines. I've had owners tell me their bike is running great, and when I take it apart for the mods they want, I discover valve train problems. Here's the latest 1 to come in. I think the owner said it had 50,000 miles on it.
    John
    These parts came in 2 weeks ago for mods.
    #67 john sachs, Apr 13, 2018
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Not good
    john sachs and francoblay1 like this.
  9. francoblay1
    K9 (2006)
    Franco
    Big D Florida and john sachs like this.
  10. john sachs
    Deltona, Fl
    harleys
    In the works.
    John
  11. piledriver
    piledriver New Member
    2005 chopper
    Are these my heads John?
  12. john sachs
    Deltona, Fl
    harleys
    Yep.:(
  13. piledriver
    2005 chopper
    big thank you John for all the awesome work, she is really purring now
    speedball jr. and Big D Florida like this.
  14. piledriver
    2005 chopper
    IMG_20180507_171333506~2.jpg IMG_20180507_171514542_BURST000_COVER_TOP~2.jpg
  15. john sachs
    Deltona, Fl
    harleys
  16. Coolbreezin
    Coolbreezin Active Member
    Northeast FL
    05 Ridgeback
    Pete
    Im still stock all the way through. What is the OEM cam on an 05 Ridgeback pls?
  17. lonerider101
    lonerider101 Member
    1972 1000cc Harley XLCH Sportster, 1986 Harley Wide Glide, 2005 Big Dog Chopper
    A 569 in my '05 chopper & I believe pretty much standard for year. Dropped to 549 in later years.
    john sachs and Coolbreezin like this.
  18. francoblay1
    K9 (2006)
    Franco
    Yup, 569 in my 06 K9 too. down to 546 cams on later years.
    Go to 585 (plug & play) and Rideee!!!!
    :chopper:
  19. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
    When you say stock, does that mean you still have a restrictor plate behind the carb? Is it an E or G carb? Do you know if you have the EPA smaller valves? If you have G-carb and bigger valves you can use the 600 cam which has way more of everything. If smaller valves or E Carb then 585 is the way to go. Curtis has the 585 that just came out of my 2005 Chopper when I upped to the 600. He will make you a good deal on it. Changing nothing else but the cam from 585 to 600 was the most dramatic change I have made. But it took all the previous mods to enable it.
    francoblay1 and john sachs like this.
