Vibrating Mirror Stems
Discussion in 'Forks / Handlebars' started by Steven Proctor, Mar 13, 2018.
  1. Steven Proctor
    GA
    '06 K9, '03 VTX1300R
    Steve
    Need some assistance for my mirrors. I have some nice aftermarket flame mirrors that vibrate loose. Especially on the left side. The mirror itself is fine, but the stem comes loose at the bars. I don't want to over tighten and snap or strip the threads. Anyone else have or had this issue? Any help and suggestions in resolving this is greatly appreciated.
  2. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Blue lock tight.. it's ur best friend on the entire bike.. I used it on my mirrors a few years ago and haven't had an issue since
    francoblay1 and Reddickracing like this.
  3. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
  4. HMAN
    HMAN Just like to ride
    Ks
    Harry
    New bushings on the handlebars.
    francoblay1 likes this.
  5. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
  6. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    I think he just did new bushings after he chipped his paint on the tank.
  7. HMAN
    Ks
    Harry
    Ahhh...well then never mind.
    bdm7250 likes this.
  8. bdm7250
    bdm7250 Guru
    Doug
    Just remembered his post about chipping his paint, when I hear about something like that it sticks with me.
    HMAN likes this.
  9. Rottweiler
    Rottweiler Well-Known Member
    Elizabethtown, PA.
    2004 Chopper, 2014 HD Road King CVO, 1985 FXWG
    Todd
    lock tight, lock tight and then add some to the holes also.
  10. SB03chopper
    SB03chopper Active Member
    St. Louis, Mo.
    2003 Big Dog chopper, 2004 Honda 1800 R vtx
    Steve
    I have not put lead into my bars yet, have the smelter, looking for right inside dia. aluminum pipe to fill with lead. Put when I put my mirrors on same thing happened with left mirror, so put star a washer on them, and they stay put now. If you handle bars move a little, then need to replace bushings with neoprene ones that took care of a lot of the vibration.
  11. SB03chopper
    St. Louis, Mo.
    Steve
    My bike is an 03 Chopper with HD controls.
  12. Steven Proctor
    GA
    Steve
    Thank you for the suggestions. I did use the blue locktight last night. I put it on around 5pm and let the bike sit and cure for about 12 hours. On the ride into work I didn't have any issues. I will go on a longer ride at lunch and see what happens. Yes I did replace the bushings earlier, I had to use the rubber ones. Those were the only kind that were readily avaible for the time frame. I am not sure about handlebar vibration. SInce this is my first BD, it is hard to tell the difference. Riding the BD and the VTX is different all the way around. I will try and pay more attention. But the bar mod does sound like a good idea, especially for the long rides. Again, thanx to all for the help.
  13. badyellowvette
    badyellowvette Active Member
    North Central PA
    2008 K9
    Jim
    Has anyone tried any of the other cures for vibration. The anti-vibration product you see for sale or any homemade thing you can do. Seen one where someone filled a plastic hose with lead shot, used silicone to seal the ends and inserted it into the handle bars. He said it worked great.
    Looking for something to buy or make to help with my hands going numb from vibration.
  14. HMAN
    Ks
    Harry
    I started with a good set of poly bushings for the bars, then happened across a set of Vibronic? bar inserts. They pulled most of the vibration out. They dont make this brand anymore but it looks like a company named Fasst makes something similar.
  15. badyellowvette
    North Central PA
    2008 K9
    Jim
  16. HMAN
    Ks
    Harry
    Ive got a set of Wicked Image mirrors on the Pit. Other than normal vibration, never a problem with them coming loose.
    dentdude36 likes this.
  17. bdm7250
    bdm7250 Guru
    Doug
    dentdude36 and HMAN like this.
  18. bdm7250
    bdm7250 Guru
    Doug
    Sure do...
    Well...Sue does..:oldhardlaugh:
    dentdude36 and BWG56 like this.
