What Kind of Bolt Is This?
Discussion in 'General' started by MossBerg590, Apr 18, 2018.
  1. MossBerg590
    MossBerg590 Active Member
    Full Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    I need to get another bolt bit about 1/2" longer. It's for the air filter bracket that threads into the head. Is this like a self tapping bolt? Can I use just a regular one? I need a 3" chrome one thread is 1/4 20. Local stores don't have anything and can't find online. Any idea where I can check if I can't just use a regular bolt? Thanks
  2. pknowles
    virginia
    paul
    That doesn't look like a stock bolt to me
    BBChopper and Unsprung like this.
  3. Brandon Downey
    Brandon Downey Active Member
    Full Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    I can't see where you're from on this tablet, but I have had good luck at a home improvement store called Menards here in Indiana with finding replacement hardware.
  4. MossBerg590
    Full Member
    Arizona
    Tyler
    It's not, it is the bolt that came with the D&M bracket kit for the D&M Spike
    tilemaster likes this.
  5. MossBerg590
    Full Member
    Arizona
    Tyler
    I'm in Arizona, I can look it up online but not sure what the proper name is for a bolt that is cut like that. Unless it's not needed, then I can order a basic button chrome bolt
  6. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    the self tapping part of the bolt would only be needed the first time it was run into the hole. after that, a standard bolt is all you would need if it runs in all the way.
    Butch Cassidy and Mike manson like this.
  7. MossBerg590
    Full Member
    Arizona
    Tyler
    Thank you, I'll just order a regular chrome bolt.
  8. pknowles
    virginia
    paul
    That groove is too long for a self tapping screw. Wonder if its for breathing or venting.?
    tilemaster, SMCT and chubs like this.
  9. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    that IS a possibility but it seems like that is not what it would be for since it would only vent to the inside and not allow gases to go anywhere. i don't remember ever seeing tapping threads going that far up on the shank of a bolt. does make a man scratch his head and say WTF?
    pknowles likes this.
  10. SB03chopper
    SB03chopper Active Member
    Supporting Member Full Member
    St. Louis, Mo.
    2003 Big Dog chopper, 2004 Honda 1800 R vtx
    Steve
    Get a hold of S&S and ask them, that long of a bolt with a channel cut in, is special made for a reason.
    SKOGDOG likes this.
  11. MossBerg590
    Full Member
    Arizona
    Tyler
  12. MossBerg590
    Full Member
    Arizona
    Tyler
    Looks like all their kits use those bolts, wonder if it helps it not loosen up as easy?
  13. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    That is a breather bolt, for a 107ci.
    HMAN, dentdude36 and BWG56 like this.
  14. bdm7250
    bdm7250 Guru
    Doug
  15. pknowles
    virginia
    paul
    Trainguy and bdm7250 like this.
  16. bdm7250
    bdm7250 Guru
    Doug
    You might as well take the day off and rest up.. :)
    dentdude36 likes this.
  17. pknowles
    virginia
    paul
    Only putting in 4hrs/day now. Hopefully i can make it.;)
    bdm7250 likes this.
  18. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :agree::old2:
    tilemaster, bdm7250 and dentdude36 like this.
  19. MossBerg590
    Full Member
    Arizona
    Tyler
    Weird, wonder why DM uses it for all their air filter bracket kits. Guess I'm good to replace it with a standard bolt
  20. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    thanks for the information.
