What Kind of Bolt Is This?
Discussion in 'General' started by MossBerg590, Apr 18, 2018.
  1. HMAN
    HMAN Just like to ride
    Supporting Member Full Member
    Ks
    Harry
    It may be stronger than the center drilled breather bolts....?
  2. MossBerg590
    MossBerg590 Active Member
    Full Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    Idk, weird that they use it in that kit since The 117 doesn't breath through the bolts
  3. HMAN
    Ks
    Harry
    Most likely a "generic" kit.
    pknowles likes this.
  4. MossBerg590
    Full Member
    Arizona
    Tyler
  5. MossBerg590
    Full Member
    Arizona
    Tyler
    Anyone know of a good source for bolts? Zero local places carry a 1/4-20x3" chrome button head bolt. Search online and can only find a few sites but it's like $4 for the bolt and $10 for shipping and will probably take awhile to get here.
  6. tilemaster
    tilemaster Member
    Full Member
    PALM COAST FLORIDA
    2004bigdog pitbull
    JOHN
    My dm spike kit I had 2 bolts that go into the head the had a whole in them for the little chrome metal filters can be used instead of the small filter between the tanks , but they don't look like mine at all , I would guess that the just change the style of getting air in there
  7. tilemaster
    tilemaster Member
    Full Member
    PALM COAST FLORIDA
    2004bigdog pitbull
    JOHN
    As long as u put a small air filter between the tanks u just use regular chrome bolts, but u need 1 filter or the other. Good luck
  8. tilemaster
    tilemaster Member
    Full Member
    PALM COAST FLORIDA
    2004bigdog pitbull
    JOHN
    Breathing
  9. tilemaster
    tilemaster Member
    Full Member
    PALM COAST FLORIDA
    2004bigdog pitbull
    JOHN
    It's for venting if u don't put the small filter between the tanks but the length u will need because when u put the bracket onto the carb the left and right bracket holes that line up to the heads. It's going to need washers behind the bracket to the head bolts. DM's spike is a nice piece I have a pit bull and I needed washers unless the newer ones have small spacers but I doubt it
  10. tilemaster
    tilemaster Member
    Full Member
    PALM COAST FLORIDA
    2004bigdog pitbull
    JOHN
    Bro that things not moving after u put the small 3 screws into the carb u will see the space need for washers don't tighten the 3 bolts like they are staying in there because u will be taking the right back out
  11. tilemaster
    tilemaster Member
    Full Member
    PALM COAST FLORIDA
    2004bigdog pitbull
    JOHN
    I have the 04 anniversary addition with there trial of the 117 cu inch to see how it goes but I bought the dm spike,bracket,and jet but mine has the vent holes in the heads then they put the 117 cu inch motor on 05 model from there on out...with the emissions and 300 rear tire, and right side drive. Hope the info helps
  12. BBChopper
    BBChopper Supports 2 Disabled Vets
    Fellsmere Fl,
    2005 BDM Choppa "Wild Fire", 2011 Electra Glide Ultra Limited "Swamp Rat"
    Pablo
    A Vent Bolt, a crappy one but thats what it does.
  13. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Not the same 117 between 04 and 05 even, I suppose there might be a few late model 04's possibly but not likely.
    Difference is S&S Super Sidewinder vs the S&S Super Sidewinder Plus. (SSW+). The only difference between these engines entirely is the breathing system. Considering the engine has been around since the 80's can't expect much!
