allenmp
chop03
ok new carb and Ultima single fire ignition setup couple questions
when static timing I get the T:F in the little window but to get the led to come on its turned so much I can't get the bolts in so I set it approx. where the last one was and started right up let it warm up a few mins and took off very little power at all if I rolled into it hard lines out and took off like a bar outta hell.
is my timing close and jets off I have the 31&78 setup on the jets
shit can't remember if I took out the aux. plug in carb would that make that big if difference at low speed sounds like shit and hardly any power till I hammer the throttle any suggestions
will pull bowl and make sure on the vent plug
thanks Mike
thanks Mike
