lonerider101
Now, after pressing the 'Run' button with key on does yur stater turn over by pressing 'Start' button?
Hilarious!!!!!!Now, after pressing the 'Run' button with key on does yur stater turn over by pressing 'Start' button?
Derick has new key switches avaliable.Well, jumped starter and it turned over. Weird thing is when it turned over the speedo went blank and headlight stopped working in position 3 of key ignition. If I turn key to position 2 the speedo comes on but not headlight. I disconnected battery, reconnected and then everything worked again in both positions.
I still have not been able to get Thunderheart to light up, is there a way to bench test that? Where is starter relay located?
Is there a way to test right side controls board? What would be a good cleaner to spray in the control board housing and clean it out?
I know my key tumbler is lose at mounting, but it still turns everything on. Does anyone have recommendation for aftermarket key FOB that I could install to eliminate the tumbler all together?
Thanks,
Dray
Hilarious? What I mean't was after disconnecting/reconnecting battery did it help the handlebar functions as did speedo & headlight? Has been said that key ign switch is pretty much ol' universal tractor style that can be purchased from local auto shops for cheap(no BDM keys) - sure u recognized that from all yur toys. I'll pull out my manual when I return from church to see if shows handlebar circuit board diagram.Hilarious!!!!!!
No, I'm right where I started, except I know motor is not seized, starter works, battery is good. It's electric, so trying to figure out how to test components without having to spend $2k on all of them.
I saw a BDM 3-position switch offered - possibly for accesseries, etc. & yes u can test each ign switch terminal with meter or continuity light for fire. Then hook jumper wire from 1 side to other or battery if no fire coming thru.I see you said something about 3 position key switch!
I only have 2 positions......On and Off. Maybe something to look at. It can be tested and/or bypassed to help figure out if it is the ignition switch.
Nope, not me. But would be nice to find out how the FOB was installed.My stock had only had two positions, this is the key tumbler that came with WP+ and was told it needed to be put on. Not a direct fit, has some play in it. Out of town for business all week so she's gonna sit for a bit.
I did see someone awhile back put a keyless FOB system on their Dog, bike was yellow, maybe Franco?? I cant find post but should probably put something in upgrades forum if I still can't find. Just wondering if there is dog specific model out there, have had issues with key tumbler in past, time to ditch it.
When I get back, time to tear everything apart and get a good look at wiring.
What can I use to clean control board with out damaging them?
Thanks guys.
Try to follow this. Since day one, you turn the key on and these are the lights that go on normally, right? If yes, I'm going to rule out the black box because it can cycle thru programs at the fob cycling and returns back to normal start LEDs with key on only. Correct me if I'm wrong.... when it turned over the speedo went blank and headlight stopped working in position 3 of key ignition. If I turn key to position 2 the speedo comes on but not headlight. I disconnected battery, reconnected and then everything worked again in both positions.
Go to the starter motor, eye the cable up to the relay from the motor side. Hot side battery cable goes to relay. At those two points, WATT are the odds you find it.I still have not been able to get Thunderheart to light up, is there a way to bench test that? Where is starter relay located?
It seems the board might be OK. I'd more chase grounds. Say there are two types of grounds: sensor grounds and 12v grounds like lights and power to the motherboard. Motherboard converts 12v to 5v and can you see maybe a group of grounds meet at a certain point or junction, or ground to frame? Some ground junctions are in the wire harness. These sometimes are taped up block? Say at that block that may be found along the main harness and could stick out on its own? You pull the tape back just enough to see the junction box and find heat melting the plastic off the wires? Sending hot to ground could have a no start effect... sometimes. So I'd chase grounds for heat related variables and tightness if frame mounted.Is there a way to test right side controls board? What would be a good cleaner to spray in the control board housing and clean it out?
After 5 years I'm sure you know the sequence to starting. Brew knows the steps to starting, so I assume you have to follow those steps to start.I did test green wire to starter and I get nothing when "start" button is pressed.
This is going to be off the wall, but what are the odds the bike starts, you disconnect the volt reg from the bike and see if it starts. For some strange reason, the blocks were burned out at those ground junction points at the harness, not the clump of wires to the frame. Showed the ground going to the volt reg to the ground box would heat up and shut the bike off. Those other grounds were part of the burn and showed no good ground integrity. So more or less I want to question these new remote grounds that are tied all together and not to the frame per say. Fucking computer bike harness setups bring the upsets. Just be careful not to upset the wrap. You're just looking for melted wires as close to that junction point of gathered grounds. Clean wires, then not at this junction.There are a few that are in a "block" so maybe something under the shrink tube.
Look for green chemical reaction at the pins. Copper is the best flow (non-magnetic meaning) so the coating is covering the copper pins. Still porous so the chemRE can stop flow. Those connectors can be submerged in vinegar. Watch the bubble begin and when they end, clean with water or first pour coke or pepsi on the pins and wash off with water. Air blow off the pins or let air dry. Computer pin wise, this calls for q-tips dipped in vinny and swab the green off those pins. Hold the pins down, black box up so the vin does not travel into the box.How would you guys test at harness plugs?
