kyle
Ok guys let's have some input. This get rather old when I want to ride...
Prime it correctly... ignition on, normal lights, run pressed, start button pushed and held.....
Sometimes it starts great and we are off, other times the starter engages for a partial crank, then stops. I will then get both turn signals flashing. Once the run button is pressed a second time, it might start or it does the same thing again. I can reset the ignition switch off a couple then back on. Normal lights and it will either start or do the same things all over.
Deka battery 310cca, on battery tender.
Heavy wires up against battery posts.
Battery has been tested -- its good to go holds 13.4 ish.
Happens more when chilly than when warm
Sent from my SM-N950U using Tapatalk
