J
JohnnyB
Guest
I was changing the fluids and when it came to changing the primary, I decided to pull the cover to do a visual on the internals and to make sure all was tight. I thought the primary chain felt a little snug (last adjusted by the dealer) and it measured 1/2" slack at the tightest spot. I read somewhere that the slack should be between 5/8" - 3/4". So I found the tight spot, and tried to get between 5/8" and 3/4". I could either go to where the dealer had it at 1/2" slack or almost up to an 1 inch of slack by just moving one notch. I tried several times to ensure I moved it just one notch and that's it........either a little tight or a little loose. I would say if I can't get it within the tolerance then loose would be better (without slapping the primary cover of course) than too tight but I'm not sure. Also, before I opened it, the transy seemed a little clunky but I'm not sure if that's related to a tight primary chain. I definitely cannot get it within 5/8" - 3/4", so should I go with a little loose or tight on the adjustment?
