That would make sense and if it has set for awhile, maybe just be marking it's spot. How much oil are you talking about??The hose appears to be crankcase ventilation as the hose is not attached to anything on the end that is not connected to the fitting on the engine case. It pumped oil through this hose once before after the bike sat up for a while when I painted it. After it ran for a minute, the oil quit running out of the hose.
Smart man right there!!! :iagree:Clean the ball "check" valve on top of the oil pump. Sounds like it's clogged allowing oil to drain into the crankcase. Drain the crankcase and refill the tank with oil and restart and see if this fixes your problem.
