clutch slipping
Brew
If you are backing off of the clutch push rod 1 and 1/2 turns that's to much free play. You only need to back off 1/4 turn.
:iagree: 1/4 turn should do it. Also what type of primary fluid are ya’ll using? Stay away from synthetic oils this may cause slippage, just saying…
phatchopper300
I just wanta ride
Yep way to many turns as RRRUFF said only 1/4 turn. And when you find the sweet spot you will find the clutch will not slip.
BadBrad
2005 Pitbull
Agreed. Just 1 to 2 flats, not full turns. If you have your primary off, pull your clutch pack and measure for proper stack height. Clutch Pack installed height: 1.96 +/-.003"
