moog5050
Finished the install tonight. Easy install if you are a bit mechanical and have a service manual, even if you know nothing about clutches (But I do now). Garry answered all questions I had and Carlos a/k/a Little-Boo was also very helpful. Thanks Guys. Worked correctly as soon as I buttoned it up.
It creeps very very slightly in first with no clutch pull. If I put my feet down, it will sit still. You can adjust this by the pushrod. Its interesting because the clutch handle has no back pressure at idle. When you rev it, its has some back pressure, but is a very easy pull clutch. Reminds me of my first bike (Kawasaki KV75) that had a 3 speed autoclutch. I took it for a test run and its a blast. I can see the real benefit of launching with no clutch and how light the pull is when shifting through the gears. It is a bit weird when you instinctively pull the clutch and there is no clutch pressure at low rpms. Anyways, so far, I think its money and time well spent. Plus I know my bike a bit better now.
My initial review is :2thumbs:
