Thanks Curtis, that's what I was looking for! From the pic it looks like it has 4 wires coming out of it and the stock one had 3, or is that just a generic pic of one and the one for my bike will only have 3?I would go with the CompUFire VR
Yea that is some good info for sure! Even though my bike is an 09 it still happened to me! If I would have known, I definitely would have changed it!for the newbs out there that are buying pre-'07 bikes with low miles (or even if they don't have low miles), there was a recall on the voltage regulators in late 2007 after there was a spate of them melting and catching on fire. would not be a bad idea to pull yours and check the number on the mounting surface. if it starts with "06", might want to go ahead and replace it.
Nah, if its the VR just change it for a good one nd you are good to go!.Holy crap. I went for a ride when it was pretty hot out and when I got back and shut it off I could smell something burning. I looked it over but couldn't find anything obvious. I'll have to check the voltage regulator out. If this is it could it have done any damage to anything other than itself?
You answered yourself... its just the ground. Mine came also with 4. Cut it short and attach it to one of the bolts from the VR to the frame. Simple, even I did it right at the first go! lol Honest, very simple.OK. Thanks Fanco. I'll check it out today. Did you get your replacement from WSW? I am a little curious about the four wire connections as opposed to the stock three wire connections. I wonder if the forth wire is an external ground connection and the stock VR does the grounding through the mounting fixture?
That's what I am wondering myself Paul! Hopefully it just was a bad VR, when I pulled the cylinders to replace the base gaskets I was checking my connections under the tank and I applied diletic grease to the connections to keep water out, well I put a little to much and didn't realize that diletic grease is a condutor and the wires were shorting out and causing the bike to die, so I think maybe that might have been what screwed up the VR, not sure though!Big question what caused it to burn?
I burnt one up during the rebuild due to a short
That was my question also, that forth wire was making me wonder where it went!You answered yourself... its just the ground. Mine came also with 4. Cut it short and attach it to one of the bolts from the VR to the frame. Simple, even I did it right at the first go! lol Honest, very simple.
Tim is 100% correct!
