tacoloco
My shifting was hard and finding neutral was difficult. After adjusting my clutch, my shifting is now smooth and finding neutral is a breeze. This is how I did it. After leveling the bike, slide the clutch cable boot to access the cable adjuster
Loosen lock nut and turn adjuster clockwise to loosen cable and give full slack to your clutch lever. It should look like this.
Now remove the clutch adjusting cover to access the adjusting hardware.
Loosen jam nut with 11/16 wrench and turn pushrod clockwise with a 7/32 Allen wrench until stops (only with light force) now turn pushrod counterclockwise ¼ of a turn and tighten jam nut.Install cover.
Finally adjust your cable to give your clutch lever 1/16 of free play. Tighten the jam nut and slide the boot back in place.
Enjoy your smooth clutch. If this adjustment doesn’t do the trick for you, consult your near BD dealer.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![](/proxy.php?image=http%3A%2F%2Fi223.photobucket.com%2Falbums%2Fdd315%2Ftaco98%2FDSCN1362.jpg&hash=739c675a544ddb75aa38e7dab56dc49e)
![](/proxy.php?image=http%3A%2F%2Fi223.photobucket.com%2Falbums%2Fdd315%2Ftaco98%2FDSCN1371.jpg&hash=48385fcaec78db8fb8079954585fc516)
![](/proxy.php?image=http%3A%2F%2Fi223.photobucket.com%2Falbums%2Fdd315%2Ftaco98%2FDSCN1369.jpg&hash=c7f0811655658c569690018108395db6)
![](/proxy.php?image=http%3A%2F%2Fi223.photobucket.com%2Falbums%2Fdd315%2Ftaco98%2FDSCN1365.jpg&hash=2ac46d27af862ab666f1976dbd28cd02)
