Starter spinning?
cavcom278
THE COMMOMAN
Well i took the dog for a stroll 2 days ago. Stopped at the bank gor some gas money and when i tried to start it back up it made a bang noise like the starter hit hard and then just a spinning sound. ? Any suggestions on where to start? I cant do much till i get back to the states on the 25th. Just tring to get a leg up on this and yes i packed my service manual to study while in on the water. Thanks in advance.
Sent from my SM-G930P using Tapatalk
1. Tooth to tooth loss. Pop in gear, move backwards/forwards [whatever is easier] so you move to any gear tooth than the one you're at now. Starts fine for a few times and then the compression brings that gear back in the same position sort of speak and the problem occurs again. You now assume the clutch basket with that big gear having a lost/worn tooth. And with that said you replace both parts so fresh cut gears move into fresh cut gears, not some worn gear about to enter half way in kind of... don't cheap out in other words.
2. Starter clutch collapse. This is where the one-way starter clutch locks one way, spins the other way. Say you saw a camel toe pass by you as you started the bike up. You held the button in too long and you snap out of it when you hear a strange noise at the engine. The reason for the one way clutch is the freewheeling design so you can watch camel toe all day and not hurt the starting system. So if there is a constant clunk or the spinning up of the starter, we look at this part as a variable.
3. Running clearance. Say a third variable would be the starter assembly moving away from the gear to gear input. We could rule this out or the bolts would have walked out already and would have been obvious with that magnet kicking in. So we can rule out the electrics, not the motor making a magnetic field to send the shaft out and engage the one-way clutch and all that.
Tap,
More from torsional twists and snaps. Two examples for breakage would be a stress riser like; a surface crack, nick, gouge, to; a bubble in the shaft from casting/manufacturing. If misaligned the tooth to tooth engagement would cock the teeth and hold the starter clutch in place, or something along those lines.
Tap,
Turtle, you seem to be mellowing out.
TapioK
Tap,
What are the changes one bike breaking 2 shafts and break 2 starter casings if all is fine in bike?
cavcom278
THE COMMOMAN
20180609_145620.jpg Thank you Mr Wright for that info . Got it all torn down and yes its the jack shaft in half. sent Curtis at wild steed worx a email about the parts I need. Thanks again for the help and info on this site. I Hope to get a email back from Curtis soon the weather is Sooooooooo Nice and I leave next Thursday for San Jaun for a week.
dentdude36
Banned
Donna and Derek have new starters with a new and improved billet nose much better off getting new rather than rebuilding, a lot of the rebuilt ones don't have the proper pinion gear and splash washers
+1 (620) 257-2009
Search on eBay big dog starter they have listings too and fast shipping 2-3 days their parts arrive to me always!
