Nope, in wet clutch there is some drag from oil between the plates. I suppose the bike doesn’t jump when you go from neutral to first gear...With the bike up on a lift and the clutch lever pulled in while the engine is running the wheel turns. Does this mean that the clutch needs adjustments? Don't notice any pulling when on the ground. Thx
Sent from my SM-G950U using Tapatalk
I have 07K9 can’t seem to get a handle on this clutch adjustment. Every sense I put the heavy duty cable in it has been hard to adjust, it wants to creep forward unless I hold the break on. I have adjusted it according to the book 1/16th play, hard to shift , almost impossible to find neutral. Is it time for a new one?[/QUOTE
Probably in your clutch pushrod adjustment. I would go there first. It took me a few times to get mine right but now it is smooth as butter.
You´ve been here since 2011... you don´t know how to adjust your clutch yet????????I have 07K9 can’t seem to get a handle on this clutch adjustment. Every sense I put the heavy duty cable in it has been hard to adjust, it wants to creep forward unless I hold the break on. I have adjusted it according to the book 1/16th play, hard to shift , almost impossible to find neutral. Is it time for a new one?
http://www.bigdogbiker.com/threads/how-to-adjust-your-clutch-05-and-newer.2025/
Clutch cable broke on a ride Sunday. Just got the new one, going to try your way, wish me luck. And thanks for the advice.unorthodox, maybe, but it works for you. just might work for others. who said one size fits all on these bikes, anyway???? thanks for the write-up.
When my clutch cable broke it revealed more extensive issues. Be careful where you ride until it is sorted out. Mine broke going 80mph uphill in freeway traffic. Not a fun moment.Clutch cable broke on a ride Sunday. Just got the new one, going to try your way, wish me luck. And thanks for the advice.
Measure the height of the stack. Should be about 1.965 There are many threads on clutch adjustment, do a search. Sounds like either the adjustment rod nut loosened up or the cable slack nut was tightened up againt the wrong side.07 Chopper I am third owner. Last owner has passed away. I adjusted the clutch per manual took it for a run clutch stopped working entirely. Check the rack and ramp looks good. Open up the primary and inspected the clutch plates and found 12? I was expecting to see 9. After looking at YouTube I’m finding out if somebody put a 12 pack in without replacing a matching rack and ramp this could’ve caused the difficulty of getting in neutral?
How do I identify if the 12 pack is factory or should it be 9? Next question with the 12 pack in there how do I check to see if it’s the correct rack and ramp?
I don’t understand and I’m mechanically inclined. How is it possible to have no clutch at all? Is it possible that all 12 pads worn down enough to have zero clutch? The ball and ramp are working correct. Open up the primary broke down the clutch and I do not see anything out of the ordinary everything looks clean no gouges scratches. Before I open the clutch I measured the distance of the pressure plate movement when squeezing the clutch handle it was 3/16 of an inch. Not knowing what it should be or even if that’s a proper measurement it didn’t seem like it traveled very far. Like I said earlier I adjust the clutch per manual instructions.Measure the height of the stack. Should be about 1.965 There are many threads on clutch adjustment, do a search. Sounds like either the adjustment rod nut loosened up or the cable slack nut was tightened up againt the wrong side.
