04 mastiff keeps dying after dyna install
Badazz
Okay after I installed the dyna 2000i ignition module it starts up great and run fine at idle. But after I put it in gear and make it a block or 2 it dies, then if I hit the off button 1 time and run button 1 time it starts right back up for about a block and then does it again. The headlight no longer works and speedo quit working as well. Any ideas on what I need to do. Was planning on taking this bike on a bit of a trip in august but really dont want to get stranded.
When it dies do you still have any lights on the speedo or is completely out? Marker lights on/off?
Check the headlight plug might be melted and why it doesn't work.
