If it's confusing, it's a Big Dog!
Looked thru all the post for last couple hours. Here's what I've got.
One month old HD battery holding at 12.45V. All of the function work as they should prior to hitting the start switch. Green flashing, yellow steady on EHC. Hit the start switch, the red ign light ncomes on on the EHC, The compression releases click, no start.
Wire at the solenoid has no power. Let it sit for 2 min, 2hrs or 2 days, hit the start button and it fires right up. It may start 2 or 10 times, but then it wont start again for either minuets, hours or days.
Took off the gas tank, checked every wire end and every connection. Cleaned and or greased. Same on EHC. Same problem. maybe it'll start, maybe it won't.
Dealer said it was the VR, replaced it. Nope!
Any ideas or found issues?
Thanks guys!
Thanks guys!
