d2ecbr
Sounds like its coming from the primary. Chain was a lil loose so i tightened the tensioner drained oil and replaced...same noise present...So after some research i was told the clutch basket could have a crack...So I pulled cover off, pulled clutch out and i don't see any signs of a crack or any metal shavins of any kind of sort. Anything to lead me in the right direction would be helpful. I am learning as i go with this one...Thank you for any help you can give in advance!
