2.5" forward extensions help
IrishGuy
1. Are there instructions for installing 2.5" forward extensions?
2. The screw that connects to the shift linkage seems to come out too far. It looks like it'll hit the down tubes. Is there something I'm missing here? :loony:
IrishGuy
Ok figured it out. I'm still having issues with the old shift linkage screw being too long and hitting the down tube. Not sure if the screw needs to be cut or if I can buy one at the hardware store.
I thought the kit came with "everything" to do the conversion. wtf is up with the screw? :confused:
newbie dog
IrishGuy...the weather today looks great for riding. Gonna put a few on the sled this afternoon. Good luck w/the DITY project.
chacha
Chaff Your EHC!!
Pics would be good. I checked my setup and even of the bolts were out too far and the shift arms were clocked wrong, it still wouldn't hit the downtube....
I had to adjust the heim joints on both sides of the ship rod to the rear. Then I cut the screw down to where it meets the heim. I don't have that cone shaped extended spacer that I've seen on some of the bikes. If you do have this spacer I would pull it out.
Good luck,
Ray
txchopperguy
If I remember, they offer a different bolt so that it won't hit the downtube...Vicky or Nelson, or R&B cycles here on the forum could confirm this.
I have some spare shifter linkages I can sell somebody for a good price...
05BDog
I had to machine down the cone spacer to make it work on my bike. When I called to check the dealer told me they do it on qall the bikes and I could just bring the spacer in. I have a lathe and mill so it was not a problem
IrishGuy
Turns out a quick 'n easy solution was to flip the spacer onto the other side. I don't have any tools to grind the spacer + screw down. Could I find a similar screw that'd fit at a hardware store?
Here's what it looks like now-
Final thoughts for anyone thinking of doing the 2.5 inch extension mod-
1. It was pretty easy to do on my own (if I can do it, anyone can)
2. You'll have to extend your break line (part included in the kit). So you'll have to re-bleed your rear break-line. I wasn't initially aware of this, but it's easy to do.
3. I'm 6" and the extended controls are a perfect fit. They feel great. Real glad I got 'em :whoop:
RRRUFF
Hey IrishGuy you are only 6" tall! :lol: Just kidding I am 6'2" tall and just ordered a set from nelson I think they will be me a little more comfort.
txchopperguy
I am 6"2" as well and just ordered from Nelson also...I am looking forward to a little more stretch in the legs while riding.
JaiLeR
It does come with a shorter screw. I was taking pick while working on mine and got so mad at that point I forgot to get a pic of that part. It seems like it went on the right, or brake, side because of the plate that was put in place instead of going directly through the control.
JaiLeR
P8RIOT
(Great avatar. JaiLeR - I agree with your signature comments - but DAMN, that last line was a bummer. :eek: :D )
rufroggy
Hey Irish, How much are the forward controls? I haven't really shopped them but was thinking about adding later..thanks
MN K9
I put them on my K9 right away. I'm 6 ft. It's amazing how much more comfortable the bike is with the controls farther forward.
