Aftermarket shift linkage for extended controls?
Mario77746
Does anyone have one? I'm putting the BDM 2.5 extended controls on and noticed the bar alone is 17 inches long. This does not include the bolts.
Thanks.
bdmridgeback
Low Down Chop Shop
I just got the prototype drawings back on my shift linkages and should have samples next week. I'll be doing these in chrome because polishing is to hard on these water jet cut parts. I can do any custom length and will be stocking all BDM standard lengths. I'll have 3-6 different designs I am working on.
skully
ref your post, if these are new extended controls, they come complete with brake extention and shift rod. all parts included. or was this used parts?
foot note; a lot of the after market shift rods are not adjustabe. meaning you can not adjusted the height of the shift pedal. one such unit a purchased, i was not able to get my foot comfortaby under the shift pedal. i ended up with wicked image, which works great, but again is not adjustable.
Mario77746
I bought the set of BDM extensions StPeteChopr advertised on my earlier post. A1 guy.:2thumbs: It included the extended linkage and everything works great.
I was looking for a linkage with some flames and skulls to match my mirrors. From what I've see (thanks Gas for the link. I've got to use that search thing some more:bang: ) $250+ for a 17' shifter linkage:confused: :confused: :confused: Holy Crap!!! I think I'll just get the BDM tube chromed for $30.
Pu239
For my '07 Chopper w/extended forward controls, I had the same problem - too long a linkage rod. I just cut off some of the rod & drilled/tapped for deeper threads to get adjustment range.
