I’m a little confused on the instructions I found online, can anyone steer me in the right direction for a video to install? I’m working on separating my shell, I’ll post a pic let me know if this is the correct way to press or separate. There is no washer on the mainshaft or the clutch shaft when I took it apart, should I be concerned? And where can I get the correct washers? Also what oil should I use and how long to soak the clutches? Tia
