Big radius heat shields
jhudson82
here goes a hopeful! i have the big radius exhaust and i am looking for the bottom rear scalloped heat sheild to replace my old one thats got a lil road rash. i have found the part number from vance and hines but to no avail have found anyone that can get them. they are shown as replaceable but by who knows. any help would be greatly appreciated!!!!!!!!
Banned
I've already had to replace 2 of them, get them from big dog dealer, but be prepared to wait awhile,thay always take 3-4 weeeks . thinkin of gettin a new set of pipes that dont hang so low in future, tired or replacing them
bob52261
bob52261
do a search i think there is some one that makes that heat sheild that will work on the vanes and hines thats a little bit shorter,so they dont drag on the ground on hard right turns
jhudson82
i have been searching for the last two days wish i could get some a lil shorter. what price they hit ya for on the replacements?
Chopper Dave
SIICK!!!
last I heard...I think someone said they were around $130 for the shorter bottom shield....then you have to cut about a inch off the pipe itself being that the shield is shorter
TCALZ06
you have to buy the shields direct from V&H only. I can tell you all 4 are $400 plus tax and shipping
BorgerBigDog
BORN TEXAN
I have one with a scratch i called Strokers in Dallas and had mine a few weeks later. I do have a new upper one i havent taken out of the box.This was a couple years ago..
whatever01
If vicki is still around I got the aftermarket , shorter version from her awhile back. You will end up cutting a couple inches off of the stock pipe for it to work, no big deal. Looks good. Mine doesnt scrape anymore.
WB Cycles
(1) VH-D308HC / Big Radius 2-2:Rear Lower Exhaust Shield - $85.00 (per item)
If you want the stock one from V&H.
f-okie
AllGaveSome-SomeGaveAll
I got another one from Mad Dog Cycles in Calif. ... I don't drag anymore because it's made about 1 1/2" shorter. :flag:
K9Anniv
What's your take on the V&H Big Radius 2-into-1 pipe? It seems to ride a little higher than the 2:2 set-up, and is supposed to generate a little more power. Here's an excerpt from an e-mail response I received from V&H:
"Thanks for the question on the Big Dog products.
We are not scheduled to do any black exhausts for the Big Dog family of products.
Regarding performance - Big Radius 2-1 vs Big Radius 2-2:
The big radius 2-1 greatly out performs the 2-2 version. On a stock 96, the
2-1 will give you 3-5 hp/tq on the top end over the 2-2. The 117 should be a
little stronger, to say the least. But you will really notice the difference
with the 2-1 on the bottom end and mid range where you will see significant
power gains as well. And the 2-1 will have a deeper, mellower sound, which
you will really appreciate with the 117.
Thanks for supporting Vance & Hines."
