Bigdogchop04
Ok I know it calls for dot 5 fluid in the manual. Never Used dot 5 in anything before. Only stuff I could find locally was motor medic dot 5 from O’reilly. It’s purple. The fluid in the reservoir is brownish like other brake fluids I’ve used in past. I assume the color is just due to likely different manufacturers. Just making sure I don’t need to bleed the whole system or anything and can add a little fluid to front and rear reservoirs. Sorry for the dumb question of the day.
