Bigdogchop04
I need some help with my rear brakes. It’s. 04 chopper and has PM calipers. It’s new to be bike and I bled (atleast I thought i did) brakes before taking it to have new rubber put on. Took her out for ride today and noticed rear wheel had a lot of brake dust on it. I couldn’t feel it pulling down or anything riding but apparently sticking or something. By the time I got home the rear brake lever had no resistance. I tried bleeding again but when I open bleed screw I get minimal fluid coming thru using mightyvac. I tried different turns on bleed screw to almost where it was going to come out. The wood you see in between pistons is between 1/2-5/8 thickness. Not sure how much farther open they can go. I sprayed them all with brake clean and cleaned them up.
My first question is do you think caliper needs rebuilt or is it a problem with fluid and bleeding?
next Question is I know big dog calls for dot5 but since this is a pm caliper do I use dot4?
And does the spring on the back of the brake pads have anything to do with much? One side of spring is mangled when I removed.
Final question: the shop that did the tires for me pointed out that there were a lot of flat washers (like 3-4 with each bolt) behind the caliper mounting bolts I’m guessing to get proper spacing for pads ?
