christer wernersson
Hi i wonder witch is the best cam for the motor hole kit live in sweden
107UNASM ENG,BD BULK(OBS) | 107"(BULK)ENGINE, 4"X4-1/4" (BIG DOG M/C) | *******DO NOT ASSEMBLE******** | 11-0446GG1 SUPER G EMISSIONS CARB | 16-2526 MANIFOLD | 32-2148 FW ASSEMBLY, 4-1/4"STROKE | 31-0047 CRANKCASE, 4"BORE, 92-99 SS BT W/CP MACH | 31-0298 GRCOVER,(POL)BILLET(BIG DOG) | 31-6205BD BILLET OIL PUMP, W/UNIVERSAL COVER | 90-1009WOS 4" PATTERN HEADS (WITHOUT STUDS).640"LIFT | 91-7021MF CYL KIT, 4"X4-1/4" BT (MFG) | 90-4916-2 COMPRESSION RELS PLUG KIT | 33-5073-S CAMSHAFT (520) 84-99 V2 BT | 33-5319 POL. TAPPET BLOCK SET, 84-99 BT | 90-4065 ROCKER ARMS | 90-4095 ROCKER BOXES, CHROME DIE CAST | 90-4036 ROCKER ARM SHAFT SET | 91-7021 CYL KIT, 4" X 4-1/4" Can i buy 585 kit its really hard from sweden Think i need electrical realese too its hard to start | 04/08/20 |
How many miles are on your bike? If it's low, you can get away with just changing the cam. If you are up over 20k miles, it would be a good idea to change the lifters. The 520 creates a bunch of compression, so the engine can be difficult to start, even with compression releases. I would recommend the 585. It closes the intake valve slightly later than the 520, so the engine should turn over a bit easier. You won't be disappointed with the 585.Hi all have this installed on my 107 pitbull 2003
16-2526 MANIFOLD |
Think i need electrical realese too its hard to start04/08/20
Hi i live in sweden and we have KM/H but i have ride 87000miles or 140000 kmHow many miles are on your bike? If it's low, you can get away with just changing the cam. If you are up over 20k miles, it would be a good idea to change the lifters. The 520 creates a bunch of compression, so the engine can be difficult to start, even with compression releases. I would recommend the 585. It closes the intake valve slightly later than the 520, so the engine should turn over a bit easier. You won't be disappointed with the 585.
You should be good with just changing the cam then. All you will need is the cam and the cam cover gasket. You can do it yourself. It's not hard. There is a tutorial by member Bowhunter. Do a search. For the parts, go to bigdogpartskingpin.com or wildsteedworx.com. I believe they ship international.Hi i live in sweden and we have KM/H but i have ride 8700miles
Did you take the oilpump when you change camI just swapped my Stock cam (.520) in my 04 chopper (107) for a .600 this winter. More pop to it and runs good. I have a whole thread on it with lots of pics.
(2) 107 top end rebuild. | Big Dog Motorcycles Forum (bigdogbiker.com)
