Good to know that it worked for you all. On mine it is a little tight but would go on with a slight tap. That said no need to since I have the 1-3/16" socket as suggested by Baker:
"Remove the following parts from the primary roughly in the following order:• Starter; 9/16 hex for battery feed and 2X3/8-16 with 5/16 allen for flange. It is not necessary to remove the starter from behind the transmission. Let starter lay on back of transmission case during O.E. primary removal and belt drive installation.• Outer primary; 14X1/4-20 cap screws, 3/16” allen• M Motor sprocket nut; 1-5/16 socket with impact. Set nut and washer aside. It will be re-used on the belt drive motor pulley• Chain adjustment shoe nut; 9/16” socket• Remove throwout bearing on clutch with medium size snap ring pliers• Remove clutch nut with 1-3/16” socket and ½” impact gun. NOTE: lefthand threads, clockwise to loosen• Remove clutch, motor sprocket, and chain as a complete assembly"
As posted before, proper is 1-3/16" for clutch and 1-5/16" for engine. As GasMan indicated, 30mm may work if that is what you have at hand, not sure of what metric would work on the engine side, but the two SAE sizes will work!
