gaddog
Okay... I'm back and it's been a bad month for the big dog. I'm still sorting out the damn electrical issues but I've been able to ride the Pitbull a bit this summer. At the end of the last month I encountered the dreaded "clutch hub nut" issue (was on a short ride around town and the clutch lever went slack). Searching the various threads found the solution (split primary and tighten aforesaid clutch hub nut to 120lbs) and I was able to deal with it. HOWEVER... the clutch had been starting to slip when I got on it in 4th, 5th and so on. So I figured while I had the primary split I'd replace the clutch pack. I ordered a new 9 disk from Energy clutches and put it in. Started to pull out of the garage and notice it was slipping from the get go in 1st gear. I have now had the primary apart 3 times trying to diagnose the issue. I called a Big Dog dealer and after 3 or 4 calls was able to get someone that explained the dome height issue. I again split the primary and used a straight edge across the top of the clutch retainer and measured at the outside of the retaining ring and again on the outside edge of the clutch pack and it measures .043 diff. The overall clutch measured 1.963 when I installed it and the old clutch was 1.943 (a little bit of wear). Apparently shimming is not the issue here (which is not covered in the service manual). Suggestions? I did find a thread that indicates a stiffer diaphram spring might be needed for the 05's (bdm part# 120-000007-00). Is this the issue or is there some guru type clutch adjusting tecnique I'm missing here. By the way... anyone know the torque specs for the four bolts that hold the clutch pack and the retainer ring to the basket?
