bruce
So, I just received my Condor wheel chock, and it was very simple to put together. I ended up picking the number two slot for the cradle, which I thought I saw somewhere on this website. But when I drove on the condor wheel chock which you want to do very slowly especially if you're by yourself, it just did hit the inside tip of the fender. So, what I did is loosened the front fender bolts there's four of them two on each side and lifted the back of the fender which it did lift up just a little, with that being done it drives on and doesn't touch it all, just thought it'd be good information for people buying these for a k9. Plus, if this doesn't work. you could take the fender off and just egg the back bolt a little so you could lift the back of the fender just to clear more if needed.
