Hi all, new to the forum and new to BD but not new to bikes. I have my HDs that I do all my own work on. Picked up an 06 Mastiff with 8k miles. Bike is mint other than the clutch dragging a little. Figured it would be a clutch adjustment and call it a day…nope.
Been through the whole clutch and cable adjustment and I discovered the cable adjuster was busted from someone over tightening the jam nut and I couldn’t take out all of the slack. Surely that was it and a new cable would fix that right up…nope. She still drags a little with clutch lever in, but enough I can control with my legs or a little brake. Replaced fluids with fresh redline primary as well. Old fluid was full of grey clutch material.
Seller is legit and not a dirtbag. Continues to offer money back if the problem turns out to be bigger than expected. They had the clutch replaced not long ago by a very reputable shop here in SC. Going to call them tomorrow and see if I can get info on what clutch was installed. Definitely has the 12 plate ramp.
Before I go hunting in the primary, am I missing anything simple? Appreciate the time and help
