EHC fault need help
Tobster
I have an 04 big dog chopper that Ive ridden for 2500 miles without any problems. Well now I have one and need some advise. I noticed the left turn signal fault light coming on with the ignition off every once in a while. Now its always on with the switch off. Have checked all wiring and led bulb. Everything works when the bike is running. Also no fault when the bike is running. Any ideas would be appreciated. Thanks in Advance.
Dennis
Check your connections
Tobster have you washed it or gotten it wet recently? Check your connections. Take your left handlebar switch housing apart and make sure your mini board is clean. Use dielectric grease on all connections. Also make sure there's no fault at each of the light connections. Chase all the little stuff before you wind up at the EHC.
Richard R
If you have a shop manual, they have a good set of schematics you can trace out the wires in & out of the ECH Its not that hard to test, It just takes some time.
Tobster
Im thinking EHC. I have washed the bike but I pulled apart the connectors under the tank and the ehc no water in them. I do have a service manual and the way I understand it works is the ehc shouldnt sense a fault unless the ignition switch is on. Thats the part I dont get.
dantep
Same bike
Have the same bike as you. I out on a wireplus just to have the security, if you decide to to that let me know if u have any questions. Already sold the ehc or I could offer it to you.
Richard R
If you look at the schematic you will see it has some latching relays, It may have one stuck, the lights come if you have a short or a open as per. the book. But if it cones on after key is turned off is like you have a back feed. I have the same bike my ECH is bad as soon as I get the money say GOOD BY to it HELLO wireplus.
Tobster
Well thanks for the info guys. I think I will run it tell it goes then put in the wireplus. Hey Jim thanks for the offer I might have to take you up on that when I get the wireplus.
Tobster
Hey bigdogbro1 I checked out the left handler bar control and wiring. Ohm'd out all the wiring from the handler bar to the ehc and from the turn signal to ehc. All wiring looks good. Road it last night now light is not coming on. Pretty sure It wasnt a bad connection so I will keep an eye on it and see if it comes back on.
Tobster
I wish it only had 2500 miles on it. Its got 12000 on it. Ive only owned it for 2500 miles. And your right I do need to ride more.
f-okie
AllGaveSome-SomeGaveAll
Sorry bro-I'm pushing 40,000 on my K9. But I'll be putting on several more thousand this year. Ride safe but ride..:flag::2thumbs:
