ehc? ignition module?
d2ecbr
06 ridgeback. Recently the plug wires like to vibrate off the coil. Well it happened yesterday and must of hit one of the terminals on the coil as i was trying to pull off the road while it was still sparking. Pulled over pushed wire back on. No more headlight. So just said screw it and started on my way home. but needed to stop for gas and at that point found out key switch doesn't kill the power no more. Bike would not fire. ended up having to have it towed home. I wouldn't think it'd be the coil bad since it did fire, but i have no clue where to start with this issue. any help would be appreciated....
Unplug the key switch didn't make a difference.
EHC module is 171-000002-00 which kinda has a burnt electrical smell, any other way of telling if its bad?
On the EHC, there are 2 rows of led's. the light in the 2nd row(closest to back tire) is lit up red...
The auto decompression clicks in still. and thats all it does...
i realized i posted this in the wrong section. So i do apologize for not putting it under help wanted first!!!!
d2ecbr
I officially figured it is my EHC after i checked the volt to my starter and had none and that wire goes directly into the ehc plug...So after that i called and I spoke w/Big Dog, The kit for the 06 Ridgeback won't be done for another 6 weeks. It comes w/a hole new battery box and all for my bike. But will cost 550-600 bucks. I think if everyones ranting about this wire plus kit its time to buy one up and start the process!
Little-Boo
:2thumbs: Call Jake his web site is below my signature (LOWDOWNCHOPSHOP) . He will fix you up and and help with any questions you may have on the install. Wire Plus is proven and the way to go.
Carlos :whoop:
