electric,power
well shes been doing pretty good until yesterday, went to fire her up and there wuz no power going anywere, besides the lights on the brain, they all lit up, but nothing no were else! hoping someone can tell me something about whats going on !
I know you put in a new battery, but that does not mean it was a good one. Seen brand new batteries bad from the factory. Have it load tested. Also recheck your connections everywhere you have done work. Maybe one is loose? Always return to the last thing done. Its usually related to the problem.
ok checked everything,cant see a problem, question 1. on the ignition module, when you turn the key on does the red light come on before you push run , or after, because as of now its not coming on either way! and another thing is sometimes the head light come on verly when i turn the key on , but if i push bnrights it automaticly goes dead , as if it has a dead battery, but i got a new battery, but when i turn the key on the brians lights light up bright ans the go from right to left and cut off but the last two light stay on and one is red and the one below it is green and it stays flashing , does that mean anyrthing?
No red light on ignition? Test ur cam sensor. Pull the headlight bucket open n check the connector too. If its still plastic, upgrade to a ceramic connector, they cheap.
Yep. Ignition module should show a solid red until you crank it and then it should blink while cranking. If not, it could be a bad cam sensor. Its in the nose cone so it can get hot and fail...lol. Replaced a few of em. They fairly cheap. Get one from Curtis @ HDM. The cheaper asian versions dont last long.
Mikeinjersey
I'm finding your description of the issue hard to follow. If you can take a picture of the EHC (brain) with the key turned on so we can see which lights are staying on. The red lights staying on are probably fault lights and will give us a place to start troubleshooting.
Do check out your headlamp as HMAN suggested because it is a very likely suspect when it comes to causing a short and electrical issues.
alleight when the lights are all lit i just turned the key on , and when you see the pic with the yellow and green light thats after the orthers cut off and the yellow stays on and the green blinksIMG_20230918_222408095.jpgIMG_20230918_222707347.jpg
Mikeinjersey
That seems normal as far as I know. Initial lights on is a self check , My bike (07) has the yellow light on with the green light blinking just like yours. This file may help identify where the issue is even though your EHC seems to be different.
Disconnect the wire to the starter for now while troubleshooting. With the key on your headlight and blinkers should be lit . Select run and you should see your ign module light. Hit start and your headlamp should go out and you should hear your compression releases click. What fails and do you get any fault light?
Very important, did you check your headlamp connector and bulb? Post #4
thats my problem , when i turn the key on , theres no turn signals at all light up, and the head lamp verly lights up, and if i push any button, it goes out , until i turn the key back off and back on again
Mikeinjersey
It seems as though you have a short somewhere. The unusual part is your not getting any fault lights. Assuming your new battery is good and installed correctly you will need to disconnect individual circuits one by one and look for a change in symptom. You may need to go under the fuel tank for the front lights and headlamp wires. The connector for your rear lights are probably accessible from under your seat. Look anywhere you think vibration could have chaffed a wire.
If you haven't done so, unplug the EHC and make sure all the wires look good and replace the dielectric grease.
If don't find anything I believe you can get your EHC tested at wildsteedworx.com.
Someone on this site may be more familiar with your specific EHC type and be able to assist as well.
I will do that, and thank each and everyone, that's helped me with what you could, I'll keep in touch and let you no how it goes. Any idea were I can get another brain for my bike, please let me no! Hey I've already replaced a few things on this bike, and if I have to replace everything, I will! Lol I love it!
Sent from my moto g stylus 5G (2022) using Tapatalk
