WRM66
I have an "07 K9 and it's having some electrical problems... First off, I have been plauqed by repeated transmission problems since last summer caused by Mancusco not putting transmission fluid back in it after having it serviced....anyhow, I have been round and round with them and finally got a new transmission out of the deal, but the bike sat for 5 months....Now a bike sitting up that long shouldn't be a problem, but I have heard of electrical problems arising after one has set for a long time, and now mine has done it....NOW, on to problem....The day after I get it back I crank it up, everything's good...I ride about 2-3 miles and it dies like you turned the key off....No power to tach, speedo, oil light...nothing. I flared the key 8 or 10 times and it powered back up and I rode on.....later that same day it does the same thing at 75 mph. Before I came to a complete stop, again flaring the key several times, it powered back up, cycled the tach and I restarted it and went on. It went about 2 weeks of riding without any problems, then Saturday, I went to ride and when I turned the key on for the first time that day, nothing....but the headlight was on, so for the hell of it I hit the run button and it fired up and ran......Now, here's the part that don't make sense, when I put it in gear, it kills it.....now I know there is not any kind of a neutral safety switch on these bikes so explain that one???....I tried it several times, same thing start up and run, but die like you turned the key off as soon as you put it in gear....I tried to leave it in gear and start it, nothing...put back in neutral and it would start, but die as soon as you put it in gear. BTW, All this time, the speedo, tach etc, is dead(no power)......after anther 20 minutes I turn the key on again and everthing powers up correctly and it starts, goes into gear without dying...ride a few miles , same issue......finally it cycles correctly and I get it back home....
Does anyone have any idea what can be causing this? I have pulled the tank off and checked all the connectors, checked all the wiring to make sure everything is tight....battery terminals, big ground on starter, terminals to ignition switch as well as the relay terminal under the seat next to battery.
Maybe a bad EHC ? Ignition switch? Any help and/or input is greatly appreciated......
Will
Will
