fork wiper seal ???
billwr
have 05 bulldog w inverted forks want to replace oil seals and teflon wider seals local shop keeps getting wrong part from big dog (wiper seals) anyone got a good harley pn or now a shop that has a new set waiting since jan for the wiper seals
mcgroom
What size are your forks?
Mine are 54mm but it is an 02' with a Mean Streets Inverted Front End.
mcgroom
The 54mm is the fork tube.
I should have the HD part number for the seals and I will check to see if I still have the BDM bushing numbers.
mcgroom
HD Oil Seal # 45875-84A
BDM Slide Bushing # 130-000078-00
BDM Guide Bushing # 130-000071-00
You need 1 of each for each fork tube.
Hope this helps.
billwr
called meen street forks said i dont need the teflon wiper seal they are known to hold abrasives and scratch the fork tubes but said they would look around monday for a set for me thx everybody
side note they also said that they went to an o ring in there newer forks
:flag:
mcgroom
An O-Ring would be a hell of a lot easier to get out than than bushings, that's for sure.
They are good guys to work with, I just got a set off trees from them a couple of weeks ago.
They said I would have them in a couple of weeks and I HAD them in a couple of weeks and they are nicer than I expected.
